10.5 Axle Bearings
10.5 Axle Bearings
The driver's side rear axle seal on my 2001 F250 is weeping. This truck has 239,000 miles on it, about 95% of them are highway miles, with little or no load in/on it. The axle has never been low on lubricant or under water. Axle lubricant was changed at 150,000 miles with recommended gear oil.
At this point, I'm assuming this condition is simply due to the age and mileage of the truck, but I am also aware that an oil seal can be indicative of bearing wear. Is there a quick check to confirm the bearing are OK before disassembling the hub to replace the seal?
Yes they just start around 200k, Preventive swaps will prevent extra brake pad purchases.
Its fairly simple repair, lots of step by steps to find on the web. I highly doubt the bearing are bad. I,v had seepage on 2 of my high mile superduties, with no bearing problems.
You will need the parking brake shoes also. Do both at the same time. Order the axle nut and shoes online to save a ton.
My backing plates are fine, only slight surface rust due to the facts that northeast Wyoming is "high and dry," our state does not use much salt or mag chloride in the winter, and I flush the undercarriage frequently. I just did the rear brakes, after a caliper failure eighty miles from home. I had to repair it in a driveway, so I did not dig into the seals. Fortunately it is still minor which gives me time to ask and learn and acquire parts and a spindle nut socket....
I will be replacing both seals and the brake shoes. They still hold the vehicle fine, but I'm keeping in mind that they are the back-up braking system too.
BIG THANKS for the help and suggestions!
www.guzzle7pt3.com/embrake.php
Parts are fairly cheap. I think I got everything off rock auto. I got the special spindle socket there or napa - cant remember which. New parking brake shoes were needed. Mine were soaked and rendered useless. Was quoted $1600 to have it all done but it wasn't a bad DIY job after finding this how-to.
fatheroftwo
03-10-2016 11:56 AM
nct53
11-07-2011 02:12 PM
toolz_not_toyz
13
08-18-2004 09:47 PM
