1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
10.5 Axle Bearings
Old 08-17-2018, 07:22 AM
SDSC4X4's Avatar
SDSC4X4
SDSC4X4 is offline
10.5 Axle Bearings
The driver's side rear axle seal on my 2001 F250 is weeping. This truck has 239,000 miles on it, about 95% of them are highway miles, with little or no load in/on it. The axle has never been low on lubricant or under water. Axle lubricant was changed at 150,000 miles with recommended gear oil.
At this point, I'm assuming this condition is simply due to the age and mileage of the truck, but I am also aware that an oil seal can be indicative of bearing wear. Is there a quick check to confirm the bearing are OK before disassembling the hub to replace the seal?
Old 08-17-2018, 09:02 AM
Griff350's Avatar
Griff350
Griff350 is offline
Yes they just start around 200k, Preventive swaps will prevent extra brake pad purchases.
Its fairly simple repair, lots of step by steps to find on the web. I highly doubt the bearing are bad. I,v had seepage on 2 of my high mile superduties, with no bearing problems.
You will need the parking brake shoes also. Do both at the same time. Order the axle nut and shoes online to save a ton.
Old 08-17-2018, 08:40 PM
SuperDutyScaler's Avatar
SuperDutyScaler
SuperDutyScaler is offline
If you live in a rust state dont forget the backing plates also
Old 08-17-2018, 09:50 PM
MisterCMK's Avatar
MisterCMK
MisterCMK is offline
This! Even if you don't live in a rust state they are probably rusted through
Old 08-18-2018, 07:22 AM
SDSC4X4's Avatar
SDSC4X4
SDSC4X4 is offline
My backing plates are fine, only slight surface rust due to the facts that northeast Wyoming is "high and dry," our state does not use much salt or mag chloride in the winter, and I flush the undercarriage frequently. I just did the rear brakes, after a caliper failure eighty miles from home. I had to repair it in a driveway, so I did not dig into the seals. Fortunately it is still minor which gives me time to ask and learn and acquire parts and a spindle nut socket....
I will be replacing both seals and the brake shoes. They still hold the vehicle fine, but I'm keeping in mind that they are the back-up braking system too.
BIG THANKS for the help and suggestions!
Old 08-18-2018, 08:45 AM
CousinCarl's Avatar
CousinCarl
CousinCarl is offline
www.guzzle7pt3.com/embrake.php
Parts are fairly cheap. I think I got everything off rock auto. I got the special spindle socket there or napa - cant remember which. New parking brake shoes were needed. Mine were soaked and rendered useless. Was quoted $1600 to have it all done but it wasn't a bad DIY job after finding this how-to.
Old 08-18-2018, 12:06 PM
SDSC4X4's Avatar
SDSC4X4
SDSC4X4 is offline
Thanks for the link. Guzzle's stuff is always good. You probably just saved me from weeding out a bunch of videos that aren't! I'm still scrounging parts. I found the spindle nut socket for about $16 on Amazon. Brake shoes actually don't look bad and they weren't wetted by the seep, but I set the brakeevery time I park the vehicle so they will be replaced while I'm in there--they don't owe me anything and I hate doing a job twice, especially for no more than they cost.
fatheroftwo
03-10-2016 11:56 AM
nct53
11-07-2011 02:12 PM
crazymut
07-06-2010 03:31 AM
toolz_not_toyz
13
08-18-2004 09:47 PM
FordFanForever
1997 - 2003 F150
06-26-2004 09:27 PM
Quick Reply: 10.5 Axle Bearings
