Sponsored by: Real Truck
Manual locking hubs question
Old Aug 15, 2018 | 06:04 PM
Lonelyowl7's Avatar
Lonelyowl7
I bought a truck and the guy converted the hubs from auto locking hubs to manual locking hubs, so i still have the switch inside. Is it ok to leave the hubs locked and just flip the switch on the inside, or is that bad for the truck?
Old Aug 15, 2018 | 06:39 PM
redford's Avatar
redford
FTE Leadership Emeritus
I leave my manual hubs locked all winter. Nothing has fallen off the truck in 11 years.
Old Aug 16, 2018 | 12:02 AM
Longranger1's Avatar
Longranger1
Trailering
I swapped the auto hubs on my 01 to warn manual and always liked to unlock them when I wasnt using the 4x4. If it's locked its putting wear and tear on the parts. imo.
Old Aug 16, 2018 | 03:24 AM
seville009's Avatar
seville009
same here, even on one truck that has auto hubs
Even lock them a few times in the summer on short errands just to move stuff around.
Old Aug 16, 2018 | 10:27 AM
brian42's Avatar
brian42
Veteran: Navy
I don't normally have my hubs locked as there's not much need for it in San Diego.
Off-roading I lock them when I hit the dirt so I can go in/out of 4wd when I need to on the trails.
I try to use 4wd at least once a month for 5-10 miles to keep everything working as seville009 mentioned.
Old Aug 16, 2018 | 12:06 PM
Batman7777's Avatar
Batman7777
I leave my Auto/Manual hubs in Auto so I can easily switch into or out of 4x4 inside.
Leaving them in manual takes mpg and unnecessary wear on the hub assy.
And.... I don't have to get out and lock them in when it's below zero or in a snow storm.
And... I don't have to worry if I got both locked in all the way or at all.
Old Aug 21, 2018 | 08:09 AM
thomabb's Avatar
thomabb
I leave my manual hubs in all winter, and a couple times in the summer to prevent the U joints from failing. You won't hurt anything.
Old Aug 21, 2018 | 09:32 AM
FractureCritical's Avatar
FractureCritical
fun fact: all 4wd rigs had solid drive spline discs in them for years before locking hubs were invented.
Warn industries will tell you that they invented them as a fuel saving and wear reducing feature back in the 40's.
They are not there to prevent your truck from blowing-up, but they sure are nice to have if you blow-out an axle u-joint (for other reasons)
FordMan57
Jan 4, 2020 10:51 PM
DieselBeast01
Jun 25, 2018 04:46 PM
forddriver17
Jan 18, 2009 05:29 PM
kswayze
Feb 6, 2008 09:17 PM
schapman
Offroad & 4x4
17
Nov 15, 2003 09:21 PM
