Strange drive-train/suspension problem...
Old Aug 14, 2018 | 09:24 AM
L-ight's Avatar
L-ight
So I am not sure if I am hearing things or it has been like this since I have driven the truck (2.5 years now). When I drive over not so flat surface I can hear my suspension/drive-train thump a lot more. It's coming from the front end. I want to say it could possibly be a bad hub bearing? It's as if the suspension is bottoming out as well. That is the closest I can describe it. No suspension mods or drive-train mods either. 95k miles.
Old Aug 14, 2018 | 09:40 AM
papadave's Avatar
papadave
with that many miles i would suspect sway bar links first, but all of the front end should be inspected. Ball joints, broken shock / shock mount, tie rod ends, could be causing the noise.
Old Aug 14, 2018 | 09:57 AM
timmyboy76's Avatar
timmyboy76
Goin out my driveway, transitioning onto blacktop, my truck feels as though the cab n bed are seperating from the frame..i fixed the front by removing the swaybar. 3x around with replacing endlinks, i finally found a permanent solution
Old Aug 14, 2018 | 10:00 AM
U9000's Avatar
U9000
While you're replacing the end links, go ahead and replace the sway bar bushings too. They will make a pretty good noise as they get soft.
Old Aug 14, 2018 | 10:44 AM
L-ight's Avatar
L-ight
I will get under later this week and take a few pics and post them. I will also try to see if I can move any parts to see if they have play in them. None of them should have play, right?
Old Aug 14, 2018 | 11:16 AM
papadave's Avatar
papadave
I'd say that's correct, sort of. End links can be checked on the ground. look for torn/squished bushings, but everything else the truck must be lifted off the ground. Keep in mind your have a heavy truck so be safe. Once you're lifted off the ground use leverage /pry bar to check for movement in ball joints and tie rods, and bearings.
Old Aug 14, 2018 | 02:07 PM
U9000's Avatar
U9000
And the swaybar bushings can feel tight until you've got 5K# of vehicle pushing against them. They're not that expensive and at 15years old, assuming they're original, they will need replacing.
Old Aug 14, 2018 | 03:18 PM
L-ight's Avatar
L-ight
Thanks for the replies. Will be tackling this job Friday.
Old Sep 10, 2018 | 08:04 AM
L-ight's Avatar
L-ight
Update:
I found the problem. It was the front passenger shock lower mounting rubber grommet. It is pretty much gone. The shock is just dancing around on the bolt making that weird thumping noise I would hear. Order 4 new Bilstein 4600s. When replacing the shocks I don't need to remove my wheels or jack the truck up, do I?
gpeade
Aug 12, 2019 08:38 PM
jacecil082
Jul 11, 2018 12:23 PM
bgreen1922
1997 - 2003 F150
Jan 12, 2010 07:19 AM
QAman
Jun 13, 2006 05:44 AM
pksignator
Apr 25, 2005 06:00 PM
