1978 - 1996 Big Bronco
'78 Bronco won't start
Old Sep 23, 2003 | 09:23 AM
kjjm4's Avatar
kjjm4
My Bronco won't start. Initially, the problem was the timing chain, which I've since replaced. While i was at it, I went ahead and changed the ignition switch (which was getting bad), the ignition module, the coil, and the rotor in the distributor. I am still not getting any spark, even out of the coil. The engine will turn over, but it won't fire. I think there is either a wire loose or a relay that has gone baad somewhere in the dash, because if i wiggle the ignition switch, I can hear a clicking noise somewhere behind the dashboard. Can anybody help me diagnose the problem? Thanks
289 sprint
1966 - 1977 Early Broncos
Mar 27, 2015 01:53 PM
redthhies
Apr 9, 2010 09:25 AM
roadready
Feb 3, 2005 12:00 AM
Kallie
Jul 1, 2003 03:07 AM
