1966 - 1977 Early Broncos
76 Bronco starting problem 302 auto
Old Mar 17, 2015 | 07:33 PM
289 sprint's Avatar
289 sprint
Have replaced the following, module, pick-up, coil, and ignition switch. After replacing pick-up it started and ran for 30 minutes, then it won't start back. Have tried another coil, pick-up, and module. how can i check system out ? Thanks Ronnie
Old Mar 19, 2015 | 05:02 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
The fact that it ran for 30 minutes is good. Make sure spark is still getting to plugs by pulling one, replace wire on plug and hold tip on clean engine block looking for a healthy spark when cranking.
Look down throat of carb, pull throttle and watch for fuel squirting verifying it's getting to engine. Got to narrow things down a bit..
Old Mar 19, 2015 | 05:19 AM
David7.3's Avatar
David7.3
Put a test light on the positive side of the battery and touch the negative on the coil and crank, you should have a flash everytime the pickup opens and closes, make sure you wire the coil correctly, yes it does matter, if you reversed the polarity of the coil go get a new one, It should be labeled, + and a -, disconnect anything you may have going to the coil, an after market tack, rev limiter, ect. Then there's always the dreaded wiring, but it is possible that you lost your prime, while repairing the ignition, just pump the gas and make sure fuel squirts from the accelerator pump. Good Luck
Old Mar 19, 2015 | 07:30 PM
289 sprint's Avatar
289 sprint
Found problem
When i replaced the ignition pick-up coil i had to cut wires and put back together, one of the wires was not making a good connection. Mad with myself but least i'm riding. Thanks for the replies.
Old Mar 27, 2015 | 01:53 PM
chrlsful's Avatar
chrlsful
Ah, success
There ya go! (U don't NEED us...
Now onta that "289 Sprint" - it's not a late '60s Falcon is it?
- Running?
frustrated ford guy
13
Aug 29, 2020 12:13 PM
Gordesky Mco
Aug 10, 2014 04:32 PM
Thomsen
37
Feb 20, 2010 10:43 AM
BottomFeeder
Aug 15, 2007 04:28 PM
8996EBBroncos
Jun 22, 2003 09:21 AM
