1978 - 1996 Big Bronco
1989 bronco 5.8 starting problems
Old Feb 2, 2005 | 10:15 PM
roadready's Avatar
roadready
have been have trouble with this truck starting, acts likes not getting fuel have changed out the fuel pumps and filter, was working for a while but every now and then it won't start again , sometimes after turing the ignition switch several times i can hear the pumps kick on then it will run, could be an ignition problem any suggestions ????
Old Feb 2, 2005 | 11:39 PM
greystreak92's Avatar
greystreak92
Sounds like it may be the fuel pump itself or the relay that triggers it. You should hear the pump(s) for a couple of seconds when you turn the key to the "run" position before you hit the start. If not, the relay and/or the pump is suspect.
Old Feb 3, 2005 | 12:00 AM
n3vyk's Avatar
n3vyk
I just got my 87 5.0 back from the shop with the same problem. It was a loose connection in the harness where it hooks to the pump at the tank. It is fine now!
travisg96
Jan 28, 2014 10:59 AM
trickydickie
Oct 29, 2012 09:01 PM
Smokeythebear
1997 - 2003 F150
Jul 17, 2010 12:23 PM
ghuffy
Nov 14, 2009 06:33 AM
wjschaller
Mar 21, 2009 03:43 PM
