Front hub only locking halfway
Old Aug 13, 2018 | 11:43 AM
Tonyhawksunderground's Avatar
My front right locking hub doesn't seem to want to lock all the way, and when I do lock it it doesn't want to unlock. I pulled the cover off and i couldn't push it all the way in like I could the left side. This is what it looks like
I'd replace the lockouts and be done with it but the fact that the middle part is off center has me worried. Should I replace the wheel bearing as well? There doesn't seem to be any play but compared to the driver side it looks wrong
Old Aug 13, 2018 | 12:05 PM
Conanski's Avatar
Conanski
I'd say the outer drive axle U-joints is seized, common problem and yes that will often prevent the hub from operating properly.
Old Aug 13, 2018 | 03:32 PM
The halfshaft spins freely, I don't think it's the u joint
Old Aug 13, 2018 | 03:52 PM
Conanski's Avatar
Conanski
Does the shaft turn smoothly when the wheels are turned at an angle?
Old Aug 13, 2018 | 03:55 PM
Yep it turns just fine
Old Aug 13, 2018 | 08:21 PM
Conanski's Avatar
Conanski
OK the axle joint isn't the problem then. Have you had these hubs apart before? After looking at it again it is possible the hub may not be assembled correctly, you probably should take the guts of the hub out anyway and inspect for damage but also try to verify that the parts are inserted correctly, I know with some of them the main locking collar can be installed either way and in one orientation it doesn't lock.
Old Aug 13, 2018 | 08:23 PM
Never been apart to my knowledge.ive owned it for 6 years and it's only just recently started acting up
Twonky
Nov 14, 2018 05:42 PM
magnumak1
May 9, 2012 10:01 PM
chapinmesa
Mar 10, 2009 12:32 PM
Uncle Weezle
Offroad & 4x4
Jan 3, 2006 05:10 PM
Munkey
Mar 15, 2004 06:10 PM
