2011 Front Shock Replacement
Old Aug 12, 2018 | 10:30 PM
smokewagun's Avatar
smokewagun
My sons truck needs new shocks all the way around, but I'm wondering what I'm getting into in front.
his truck has level spacers up front, and I'm wondering if I replace the shocks if I'll need to get the front end aligned.. I watched a video where the complete spring/shock was replaced, but not sure if doing just the shock will be more than pulling the complete coil/shock. Any advice is appreciated.
Old Aug 13, 2018 | 07:39 AM
ssls6's Avatar
ssls6
Just the shock is harder than a whole shock/spring (strut). You'll need spring compressors to replace the shock portion and that has some danger.
Old Aug 13, 2018 | 08:32 AM
smokewagun's Avatar
smokewagun
Thank you. Replacing the complete strut looks relatively simple. I'm not going to mess with the Shock alone. Thank you.
Old Aug 14, 2018 | 03:37 AM
GaryKip's Avatar
GaryKip
I was the hard-headed one that did the shock only replacement. I will never do that again. The lower arm was filled with harden mud (from the PO). I had to chisle it out. It took me 3 hr to finish the drivers side alone.
Grabber
Oct 17, 2007 07:42 PM
dmacfordshot04
Feb 19, 2006 01:00 AM
MBBFord
1978 - 1996 Big Bronco
Sep 30, 2005 11:13 AM
scotchme2
1983 - 2012 Ranger & B-Series
Apr 14, 2005 10:49 AM
willystyle21
May 5, 2004 10:27 AM
