replacing front shocks
Old Mar 27, 2005 | 03:02 PM
scotchme2's Avatar
scotchme2
!999 2wd Ranger 3.0
I like to browse my chiltons before doing any work no matter how mondane. Not being what they used to be, My book doesn't have my suspension in it. Shocks inside the coils. Will someone step me through so I don't waste any time? Thanks!
Old Mar 27, 2005 | 03:13 PM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
I haven't dont that year before, but really, it should just be a few fasteners on the top and bottom of the shock. Before starting, look to see if there will be room to lower the shock and install the new one. If not, drive the side of the vehicle you are working on up on a ramp, or use a floor jack to raise it.
Old Mar 27, 2005 | 05:58 PM
scotchme2's Avatar
scotchme2
I was wondering more about if the shock would fit out the hole beneath the coil spring or if the spring needs to come outThanks
Old Mar 27, 2005 | 06:28 PM
Ken00's Avatar
Ken00
One nut on top of the shock, two on the bottom, the shock should drop out the bottom.
Old Mar 27, 2005 | 08:46 PM
johare's Avatar
johare
I put shocks on my 1999 2WD recently and Ken is exactly right. Jack up the truck and remove the wheel and tire, three nuts and bingo - the shock is out!
Old Apr 13, 2005 | 03:14 PM
Quackhead94ranger's Avatar
Quackhead94ranger
would it be the same process for a 94 ranger w/ 4wd?
Old Apr 13, 2005 | 04:16 PM
CowboyBilly9Mile
On a 94 4x4, the rear shocks are held on via a stud and a nut on each end of the shock; the stud is c/t (common to) the chassis. No jacking required.
On the front, the lower end of the shock is held on via a stud c/t the chassis and the upper portion of the shock is threaded, has rubber bumpers, steel washers, and a nut to secure everything. No jacking required.
Both are very simple to change and the process will be very obvious when you take a look. Have some metric tools around for the back for sure; can't remember on the studs on the fronts. I think the nut on the front was a 9/16.
Old Apr 13, 2005 | 07:36 PM
Ken00's Avatar
Ken00
Spray the bolts ahead of time with liquid wrench, etc, breaking those stud off is very common.
Old Apr 14, 2005 | 05:17 AM
CowboyBilly9Mile
Correction - the lower end of the rear shock is held on with a nut/bolt.
Old Apr 14, 2005 | 10:49 AM
GrayRanger4x4's Avatar
GrayRanger4x4
Cowboy is right.you don't need to jack up the truck on the 94,but if you replace the shocks with gas shocks,then you realy have to push hard to compress them to get them on.Jack the truck up useing the fram{DONT FORGET TO USE JACKSTANDS} and let the axle drop on the side your changing,then you dont have to push the shock up as far to get it on.JMO
