Brake controller kit
Old Aug 12, 2018 | 12:06 PM
Big Cheif's Avatar
Big Cheif
06 F250 Diesel 2wd, The available new Brake Controller Kits at Ford come with master cylinder. Why would I need a master cylinder? The Ford salesman could not tell me. Thanks for your advice.
Old Aug 12, 2018 | 12:15 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
It uses the master cyl to tell the TBC when to function. Don't bother with it...keep what you have and get a P3 : Tekonsha! I just installed mine to REPLACE the Ford version. MUCH cheaper than converting to factory. Check Amazon pricing.
Old Aug 12, 2018 | 02:14 PM
p38fln's Avatar
p38fln
The Ford controller (with master cylinder) is an awesome TBC, because you get actual brake pressure to your trailer rather than an algorithm based on tow vehicle deceleration. I used one on a 2011 f150 pulling up to 10,000 pounds, it gave extremely smooth and precise braking compared to the pendulum style controllers
Old Aug 12, 2018 | 03:36 PM
RV_Tech's Avatar
RV_Tech
I would be willing to bet in a blindfold test folks would not be able to tell the action of a P3 from the Integrated Controller. Yes the ITC is miles ahead of the old pendulum controllers, but so is the P3.
Old Aug 12, 2018 | 07:59 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
The P3 however has a lifetime limited warranty and is miles ahead in pricing (lower). Cost of ITC vs cost of THE P3 IS ASTRONOMICAL !
Vlitefun
All Things Towing
Jul 3, 2015 08:55 AM
737ngdriver
Electrical Systems/Wiring
Aug 11, 2009 01:00 PM
twistedranger
All Things Towing
Feb 21, 2009 03:09 AM
gregghealy
Sep 27, 2007 05:06 PM
Rickm518
All Things Towing
Oct 21, 2006 01:41 AM
