TRAILER Brake controller fault
Old Aug 9, 2009 | 12:41 PM
737ngdriver's Avatar
737ngdriver
I just robbed a factory integrated brake controller from my old truck to put into the new truck I just boutght because I loved the way it worked in the old truck. The problem is that now the old truck is showing a "TBC Fault" on the message center when you start up the truck. It's obviously looking for it's controller that is no longer there. What I need to know is how to get it to ignore this and stop putting the message up on the message center.
Anyone got any ideas
Old Aug 10, 2009 | 12:51 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
TCB will have to be programed by the dealer. Did you also take the brake master cylinder from the old truck - it's required.
Old Aug 10, 2009 | 08:13 PM
737ngdriver
I cant take the master cylinder over to the new truck. Its a deisel and uses a whole different brkae setup. Why would the master cylinder be required?
Old Aug 10, 2009 | 09:42 PM
Franklin2's Avatar
Franklin2
I don't know much about this system, but I do know the newer trucks are loaded with computers that talk to each other. No more old school bolt ons and swaps, it all has to be programmed to work together.
Old Aug 11, 2009 | 01:00 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
The TBC uses the Master Cylinder to apply the correct amount of voltage to the trailer brake circuit . It has to know the amount of brake pressure you are applying to work correctly.
Blapensee
6.7L Power Stroke Diesel
Oct 12, 2019 03:59 AM
Rotterdam24
Oct 20, 2016 07:23 PM
Smoke2008
Jun 30, 2014 06:35 PM
phantomphixer
All Things Towing
34
Jan 17, 2013 09:27 PM
mrw1
Jan 1, 2012 06:11 PM
