Just picked up my FIRST Bronco!!
Driving home I found that it is easy to wander into the other lanes at 70mph. It has stock ride hight and 31x 10.5 BFG A/t's. would a Steering stabilizer help this????
I would check the front-end steering parts first. I assume that the Bronco you bought has Independent Front Suspension, which can be a pain sometimes to get back to specs. I would take it to a reputable front-end shop and have them take a look. Could be anything from a steering box to ball joints.
I would second that front end look over. But... my 96 wandered as well. I have added a Rough Country steering stabilizer (they made my lift, I didnt want to change brands). It has helped quite a bit. A stabilizer can mask pre-existing problems. Once you know that youre front end is kosher, then I would bolt one on.
