1978 - 1996 Big Bronco
AOD on a non AOD Bronco?
Old 09-22-2003, 03:47 PM
Capone
Capone is offline
Capone is starting off with a positive reputation.
Has there ever been any sucessful attempts at installing a non electronic AOD into a Bronco? that OD gear sure would be nice to up the MPG even more!!!
let me know of the specifics.
thanks in advance
Old 09-22-2003, 03:50 PM
Gacknar's Avatar
Gacknar
Gacknar is offline
Gacknar is starting off with a positive reputation.
An AOD sould be a simple bolt in
Old 09-22-2003, 11:09 PM
DW2455's Avatar
DW2455
DW2455 is offline
DW2455 is starting off with a positive reputation.
you can put a AOD in woth no problems, but your gona have to get TV cable set, cause you cant run the AOD with out it. DW
Old 09-23-2003, 12:01 AM
Capone
Capone is offline
TV cable set? please excuse my ignorance....as I am inundated with elliptical,
polar and parametric equations and integrals right now....the brain can only
do so much!!!
thanks
R
Old 09-23-2003, 08:26 AM
Gacknar's Avatar
Gacknar
Gacknar is offline
T.V. stands for Throttle Valve. It is what tells the transmision how much gas you are giving the engine. It is not a kick down lever. You can run a C-4 OR C-6 without a kick down lever but you cant run an AOD without the T.V. cable attached and the Throttle Valve Pressure set properly, or it will burn up in 2 or 3 miles.
Or at least thats what I understand
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
