6.0 problems
Old Aug 2, 2018 | 06:07 PM
altonlee's Avatar
altonlee
6.0 problems
I have a 2004 f350 6.0. The turbo blew, I put a new stock garrett along with new pipes. I also changed the ifp and the icp. Got it together and it did not run right, checked it out the new icp was bad, changed it and truck starts and idles good. Problem is when the rpm's go up the engine starts sounding like it is missing. Does real good to about 1700 and the higher you go the worse the miss is.
If the ifp was also bad it would not start would it?
I checked all plugs that I could have unplugged but found none.
Does anyone know where I now need to look.
The truck ran but had no power when I changed the turbo plus is was blowing smoke out of it.
All help or suggestions are really appreciated.
Thanks
Alton
Old Aug 2, 2018 | 06:16 PM
npccpartsman's Avatar
npccpartsman
What is an IFP??? Do you mean you changed the ICP sensor and the IPR valve? ICP = injector control pressure sensor and IPR = Injector Pressure Regulator
Were they both on the back of the motor next to the turbo or was one on the passenger side valve cover at the front?
Old Aug 3, 2018 | 05:24 AM
altonlee's Avatar
altonlee
They are in the back.
Thanks
Old Aug 3, 2018 | 06:15 AM
mattdoc88's Avatar
mattdoc88
Is it throwing any codes?
Do you mean above 1700rpm in park/neutral, or driving?
Old Aug 3, 2018 | 06:33 AM
altonlee's Avatar
altonlee
In park.
It is throwing a lot of codes
p102 mass airflow low input
p0113 intake air temp circuit high input
p2290 inj control pressure too low (not sure what this should be) but ae shows what is required and actual is the same.
The truck starts good as quick as always and idles good with no problem but has no power or torque on scan it shows the torque does not rise much with higher rpms.
There are other codes but none relating to engine, like seat belt and air bag.
Old Aug 3, 2018 | 06:57 AM
bismic's Avatar
bismic
Codes almost always help. Thanks for getting those posted.
P0102
Open circuit in the MAF V-Ref (vref) circuit or possibly a PCM short to PWR GND or signal -return circuits.
P0113
IAT low: -40 *F. This is the code for a disconnected MAF. Agaim, P0113 and P1102 could be caused by a broken/damaged Vref wire at the Mass air flow sensor.
Pull up the MAF pid and IAT1 pid on your scanner and watch them very closely while you wiggle the harness right where it goes into the connector up and down and side to side. If you see any fluctuation in it while wiggling it, then you would definitely want to replace that connector with a new pigtail.
P2290 (running code) on a 2003-2004.25 6.0L is most likely caused by, in order of likelihood:
1- Failing, cracked and leaking ICP sensor and oil damaged wiring at the sensor
2- A weak or failing High Pressure Oil Pump
3- IPR valve
This is a "running" operation code. P 2291 is a similar code, but is more of a "cranking" code.
The codes can be from an actual mechanical failure or even faulty programming.
So, since you replaced the ICP and the IPR, did you replace the ICP harness/connector?
Dany Ledesma
Aug 8, 2019 01:11 PM
altonlee
Oct 6, 2018 05:53 PM
altonlee
Sep 1, 2018 03:04 PM
lbo200688
Jun 28, 2014 10:20 PM
runmaster
Oct 23, 2010 07:38 PM
