Problem with door locks
Old Aug 1, 2018 | 02:21 PM
1995ranger4x4's Avatar
1995ranger4x4
The drivers door unlocks with the key, but doesn't lock with the key. The problem is that the passenger door locks with the key, but doesn't unlock with the key.
Old Aug 1, 2018 | 03:33 PM
mfp4073's Avatar
mfp4073
have you tried the simple solution and lubed them? Hose them down inside with a light oil, then insert/remove the key several times. Next hose it down again and try turning it (gently) working it back and forth to see if you get improvement?
Old Aug 1, 2018 | 03:45 PM
1995ranger4x4
They work good enough for now. The drivers side turns left only, which unlocks it. The passenger side turns left only, which locks it.
Old Aug 2, 2018 | 04:40 AM
mfp4073's Avatar
mfp4073
lol. ok. I assumed you were looking for a solution when you made your post.
Old Aug 2, 2018 | 01:30 PM
phoskins's Avatar
phoskins
I think you should go ahead and lube them now, it only takes a couple minutes. Spray some WD-40 or p'Blaster in the locks and turn the key several times until they move. If not, replacing the door locks isn't a difficult task, really.
mike L
Oct 12, 2015 09:13 AM
thefordguy
1997 - 2003 F150
Jun 12, 2010 12:20 PM
deerslayer joe
Sep 21, 2009 07:56 PM
AC75
Apr 1, 2009 05:40 PM
mfriesen
16
Nov 29, 2005 03:19 AM
