Blunt Cut Wires
Old Jul 23, 2018 | 08:58 PM
amcginthy's Avatar
amcginthy
Question Blunt Cut Wires
Ok, I've looked at many posts about the upfitter switches and pass through wires - the good news, I found all the wires needed. I'm new to auto electronics, so I'm not sure what to do with these Blunt Cut ends of wires. Do I just cut off the black end, or cut into it and splice it there, or is the Blunt end some sort of connector? I appreciate the help. The pass through wires on the 2018 F250 are already very short - cutting them shorter isn't gonna be fun.
Thanks.
Anthony
Old Jul 23, 2018 | 09:16 PM
jbrnigan's Avatar
jbrnigan
The black covering on the blunt cut wires from the upfitters is shrink tubing, to keep it insulated from the others. When you want or need power from an upfitter, choose your switch and corresponding wire, strip off the shrink tubing, then connect the wire to the circuit you want to power.
Old Jul 23, 2018 | 09:20 PM
Curt's05's Avatar
Curt's05
Wiser by FTE
Unhappy
Ford Didn't do us owners any favors with how Short these user wires are!
Especially the ones under the passengers kick panel
Old Jul 23, 2018 | 09:35 PM
amcginthy's Avatar
amcginthy
Thanks for the quick replies. That was pretty much what I thought, but figured I’d ask first.
Something tells me 3-4 more inches of wire wouldn’t really have hurt Ford’s bottom line!
by chance, does anyone know the gauge of wire... of the 4 pass through wires, one looks like it is 18 or 20 gauge... are the others 12 ?? 14 ??
thanks again!!
anthony
Old Jul 24, 2018 | 04:53 AM
2017F250131's Avatar
2017F250131
But 3 or 4 more inches per every unit they sell is...
Old Jul 24, 2018 | 05:42 AM
Curt's05's Avatar
Curt's05
Wiser by FTE
https://www.scribd.com/document/3415...-Switch-System
Ford has a web site for them
Old Jul 24, 2018 | 07:13 AM
amcginthy's Avatar
amcginthy
Originally Posted by Curt's05
thanks... I have this pdf, however, I don’t see anything in here that says what gauge the wires are. It may be here, but I don’t see it. Thanks
Old Jul 24, 2018 | 07:27 AM
BHPR's Avatar
BHPR
That doesn't look like a Ford website.... Why would I have to join for "30 free days" of downloads. Does anyone have a link where I don't have to join something to get the info?
Old Jul 24, 2018 | 07:38 AM
wildcard30's Avatar
wildcard30
I’m trying to remember the last time I hook up to my upfitters. I think they are 16 gauge. The insulation is quite thick.
Old Jul 24, 2018 | 09:44 AM
SnoqMark's Avatar
SnoqMark
This link may work better for download
https://madocumentupload.marketingas...1fb63&v5=False
Old Jul 24, 2018 | 09:57 AM
super_duty_532's Avatar
super_duty_532
Yeah, should be at least 16 gauge. I just used the brown wire. For sure it wouldn't fit in 18-22 gauge connectors. I used the next size up 14-16 connectors.
Old Jul 25, 2018 | 09:52 AM
BHPR's Avatar
BHPR
Thumbs up Awesome :)
Thanks a bunch!
Old Jul 25, 2018 | 05:49 PM
1024F250's Avatar
1024F250
So how would you hook these up? Just run a wire and then run a ground somewhere? Where are all of the connections ...are they only under the hood?
thanks
Old Jul 25, 2018 | 06:42 PM
CGA's Avatar
CGA
On the pass through wires, I heated up the ends and the covers slipped right off. I then used
Posi-lock Posi-lock
connectors to splice my wires in.
Simple and reusable, I find they work well for low amperage applications.
T.Mainus
Feb 21, 2010 10:20 PM
ptesmoke
1983 - 2012 Ranger & B-Series
Aug 23, 2008 02:23 PM
rmalottwtes30
Apr 18, 2008 03:55 PM
Homeslice
Jan 13, 2008 11:45 AM
