Will a 77 F100 2x4 body drop straight on to a 78 F250 4x4 frame without doing any modifications other than the floor tunnel? I'm talking about swapping all the sheet metal out, cab\doors, front clip and the bed. The 77 is a column shift AT and my 78 is a 4 speed so I know there;d be some tunnel work at a minimum.
Core support and front cab mounts are dead on the same. Now the rear cab mounts I am not sure about, but from the pics I have seen they are the same as well. Pretty sure the bed is a drop on and go.
Alright, thanks for the info. My truck is at the point where it needs restoration so I'm looking at a re-body using a nice donor as a cheaper alternative to redoing my truck completely.
