Transmission shift points
Old Jul 20, 2018 | 08:54 AM
tucsonford's Avatar
tucsonford
has a 4 speed automatic transmission, I think? What is the shift option? 1st then 2nd then 3rd then into overdrive then the torque converter lock up or torque converter lock up then it shifts into overdrive? I asking because when towing and a small hill comes up i see a 300 rpm rise, before it if I hit the tow button I rises about 700. I assume the tow button takes it out of overdrive but does not unlock the torque converter.
Old Jul 20, 2018 | 01:02 PM
Shadow351's Avatar
Shadow351
My 2004 doesn't have a tow button, maybe that was added later in this generation, but it does have an OD off button to lock the transmission out of overdrive. As far as I can tell my 2004 goes 1,2,3,OD,Lock Converter. I don't think I've ever caught it lock the converter in direct (3rd), but I rarely use the OD off function, even when towing it hasn't been necessary.
Old Jul 20, 2018 | 07:10 PM
pdqford's Avatar
pdqford
Yep. When you disable overdrive, the shift strategy changes as does the torque converter lock/unlock strategy.
Gstan
20
Mar 11, 2018 10:59 PM
n5926g
2004 - 2008 F150
Oct 16, 2010 09:45 AM
Douglas Walker
1997 - 2003 F150
Sep 29, 2009 11:56 AM
celliott
Jul 2, 2008 09:44 AM
plourde2002
1997 - 2003 F150
Feb 9, 2004 10:37 PM
