Ticking after plug change
Old Apr 23, 2010 | 03:45 PM
ssrider's Avatar
ssrider
Well I finally finished installing my new champion plugs today. What a pain in the @$$! I followed the TSB, even let them soak longer than recommended, and 4 plugs still broke. So after a week I finally got them all out. But here's the problem, my truck is now making a clicking sound. It sounds like its coming from inside the motor but hard to tell. Is it possible that say a small rock or something is bouncing around inside of there?
Old Apr 23, 2010 | 03:54 PM
RISUPERCREWMAN's Avatar
RISUPERCREWMAN
It's probably a piece from the old plugs.....
Old Apr 23, 2010 | 04:09 PM
ssrider's Avatar
ssrider
I dont think it is cause the noise sounds like its coming from the passangers side and all the plugs that broke were on the drivers side. Is it anything to worry about or will whatever is in there just end up bouncing out?
Old Apr 23, 2010 | 04:31 PM
hivoltj's Avatar
hivoltj
Loose plug on that side letting compression leak by, or if not loose, not sealing for some reason.
Old Apr 23, 2010 | 06:00 PM
1bad67sbf's Avatar
1bad67sbf
your not hearing the cam phasers are you. alot of the time when i do a large project like that i tend to over listen to the motor after and hear stuff that i think is new but has been doing it for a while i just never paid any attention. or is it very loud and solid sounding hits?
Old Apr 23, 2010 | 06:22 PM
ssrider's Avatar
ssrider
No its something new, the cam phasers made some noise before and still do. This new noise is more of a clicking/sqeaking sound. It never made it before the plug change.
Old Apr 23, 2010 | 06:39 PM
1bad67sbf's Avatar
1bad67sbf
does it go with rpms (faster at higher rpms)
Old Apr 23, 2010 | 09:30 PM
ssrider's Avatar
ssrider
yes the clicking gets faster as the rpms go up
Old Apr 24, 2010 | 05:52 AM
1bad67sbf's Avatar
1bad67sbf
did you clean out the holes (air) before removing the plugs?
Old Apr 24, 2010 | 07:32 AM
819jack's Avatar
819jack
ouch look for exhaust leak remove suspect coil and check boot for burn or trace of carbon deposit if no trace may the Ford truck Gods be with you
Old Apr 25, 2010 | 10:59 AM
ssrider's Avatar
ssrider
Yes I cleaned out the holes with air. I spent a fair bit of time doing each one because i feared something like this would happen. I'm praying to god that maybe its just a plug not sealed properly, but I torqued them all to 25 ftlbs
Old Apr 25, 2010 | 04:04 PM
819jack's Avatar
819jack
you should remove the suspected plugs and check carfuly if new plugs have signs of damage and try to look in cylinder if you can identify the faulty one . I would start engine without plug run for 5 to 10 seconds and hope it comes out good luck.
Old Apr 26, 2010 | 12:24 PM
gurdeniii's Avatar
gurdeniii
My 2003/F150's been making ticking sound since 30K miles. More noticiable now after 90K. Sound most prominent with load on engine between 700-900 RPMs. Ticking goes away above 900 rpm. Sounds like a weak or collapsed lifter. Plan on completing rocker arm adjustment before pulling the intake and replacing lifters. Any recommendations?
Old Apr 26, 2010 | 01:44 PM
smotherss's Avatar
smotherss
Is it possible that while changing the plugs you damaged one or more of the boots connecting the plugs to the coils. Often, these boots become weakened due to normal driving conditions and when you remove them they can crack its been my experience that the boots on number 3 and 4 have to bee bent pretty good to get them out. You may also want to inspect the spring inside the boot. It may not have sealed tightly enough aganist the plug, if it is not firmly againist the plug you may slightly pull the spring to stretch it to allow proper contact. Any of these could be causing a spark to occur causing a ticking sound. If your plugs were not tightly installed you should be smelling burnt fuel when the truck is running. I bet your just jumping fire somewhere between the coil and plug.
Old Apr 26, 2010 | 02:49 PM
819jack's Avatar
819jack
you may be right smotherss but if spark is jumping at that point then engine should be running kinda rough
