Fox steering stabilizer
Old Jul 20, 2018 | 08:28 AM
Gilley's Avatar
Gilley
Originally Posted by hobbie1
Maybe you said so - is your rig lifted or stock? Will be interested how it goes with the stabilizer
Stock everything, get it on Monday so we will see
Old Jul 20, 2018 | 08:40 AM
SGMJohn's Avatar
SGMJohn
I know this is not where you'd expect but I got mine from newegg.com, Just checked and their price is $151.27, free shipping. Brand new in the box!
Old Jul 22, 2018 | 03:16 PM
Gilley's Avatar
Gilley
Is there any video of installation from anyone that you guys know of?
Old Jul 22, 2018 | 04:35 PM
TXSD6.2's Avatar
TXSD6.2
Gilley,
I haven't seen one - there may be. I will say that it's a very easy diy / bolt on project to take on even if you've never swapped anything on the underside of your truck. Climb under there and look at how the current one is installed and there is only one way the new unit can be installed. Literally two bolts. Knowing this, and having plenty of pics of the stabilizer installed available, is all you need.
The hardest part (and it's not hard at all) is getting the old one off. I bought an $8 Harbor Freight pitman arm puller and used it to pop the old unit off once the bolts were removed, as it gets wedged into place and would be difficult to remove without such a tool. Using this tool to remove the old unit took less than 1 minute.
I had never used a pitman arm puller (really just like a twist clamp) or swapped any suspension components before and the whole job took me about 45 minutes taking my time. The swap is well worth the time and money.
Old Jul 22, 2018 | 05:05 PM
jimzpsd's Avatar
jimzpsd
Originally Posted by TXSD6.2
Gilley,
Good explanation, couldn't have said it better.
Old Jul 22, 2018 | 05:20 PM
Gilley's Avatar
Gilley
Gilley,
Thank you for the awesome write up. I'm not very car savy and you made it very easy for me to do. Is the sweet spot for the pressure 20 then? Gonna wait until I get a good gauge but just making sure before I let it out. Or what do you recommend
Old Jul 22, 2018 | 08:48 PM
jimzpsd's Avatar
jimzpsd
If your referring to the nitrogen pressure in the steering stabilizer being set to 20 psi, I wouldn't touch it, one fast poke with a gauge and you'll probably let it all out, its not like a car tire, the cylinder has a very small area inside (hence per square inch), many are fooled by this.
Old Jul 22, 2018 | 08:53 PM
Gilley's Avatar
Gilley
Okay good to know. Thanks. Thought I read people were letting some out. Got it installed and can't believe how big of a difference it makes thanks all for your help!!
Old Jul 22, 2018 | 09:10 PM
jimzpsd's Avatar
jimzpsd
Your welcome, I was blown away too when I installed mine.
Old Jul 23, 2018 | 12:48 AM
hobbie1's Avatar
hobbie1
Question for you all - after installing the Fox stablizer did you have any issues with the steering wheel being off center or any drifting / pulling left or right when going down the road?
Old Jul 23, 2018 | 04:45 AM
Busa 1 Dave's Avatar
Busa 1 Dave
No issues whatsoever....
Old Jul 23, 2018 | 05:27 AM
Bigblock17's Avatar
Bigblock17
At first I noticed a very slight gradual drift to the left after I installed mine. After a day of driving it didn't bother me at all. My steering wheel didn't go off center either.
Old Jul 27, 2018 | 12:14 AM
  #28
hobbie1's Avatar
hobbie1
Now that you have it installed for a few days...... how is it going - still tracking straight?
Installing mine tomorrow night after work.
Also - do you know the torque specs?
Old Jul 27, 2018 | 10:18 PM
  #29
hobbie1's Avatar
hobbie1
Update for you all .......
First - Our truck now drives perfect. Anyway as perfect as to be expected for a stock height HD F250 truck.
What did we do:
1. Installed FOX 2.0 Performance Series IFP shocks Front # 985-24-154 Rear # 985-24-151
2. Set cold tire PSI as follows: Front 63PSI Rear 67PSI
3. Installed FOX 2.0 Performance Series Stabilizer IFP # 985-24-001
Truck is a 2018 Lariat 6.7 Diesel crew cab with the 6'9" bed - FX4 package - 20" rims factory Michelin tires - 7400 mile on the OD.
Drove her on the freeway - drove on some really bad out in the country roads...
Truck is now tight - No longer feels like I must hang onto the steering wheel on rough roads. Bump steer - rocking steering is gone.
A pleasure to drive. We are ready for our 2600 mile North West trip in September.
We are happy....
chad77
Feb 9, 2017 04:57 PM
crazed87bronco
Aug 30, 2015 08:57 AM
65F100project
Oct 2, 2006 02:30 PM
BFR250SD
Jun 29, 2006 10:16 PM
joe black
Nov 15, 2004 06:35 PM
