1978 - 1996 Big Bronco
Speedometer Jumping
Old Sep 22, 2003 | 10:11 AM
HILDJO's Avatar
HILDJO
Talking Speedometer Jumping
Maybe someone has had this problem or knows what it may be. When I start to drive my 93 BRONCO the speedometer jumps or stays at zero, it shifts hard, after a few miles it quits and all is fine. My ABS light is on all the time also. Thanks
Old Sep 22, 2003 | 10:21 AM
Vanhecht's Avatar
Vanhecht
Speedometer Jumping
go here cuz its the right place to post and you will get better help then the old farts in here can give
Old Sep 22, 2003 | 01:25 PM
AlM's Avatar
AlM
Speedometer Jumping
good advice! hope it helped him; if not...https://www.ford-trucks.com/forums/s...2B%25252Bjumps
Old Sep 22, 2003 | 04:27 PM
sluggslime's Avatar
sluggslime
Cool Speedometer Jumping
Actually, the very same thing is happening to my 92' bronco and just today I went to a junk yard to purchase an instrument cluster. I did some research and it seems that this is sometimes misdiagnosed as a bad abs module. I scanned the obd and the only code it came up with was a poor signal from the vss in the tranny. I will install it tonight and hopefully that will be the end of that... oh by the way, I got the cluster for $100.00 in pretty good condition compared to $600.00 at the dealership as a special order part. I will let you know if it worked.
Old Sep 22, 2003 | 04:35 PM
sluggslime's Avatar
sluggslime
Speedometer Jumping
oh, and just in case you are curious about why the cluster, its because the programable speedometer/odometer module (PSOM)is intergrated with the cluster. The dss in the rear diff sends to psom, psom then send to abs module and to vss in trany. that is why tranny is acting up and why your abs light is on.
Old Sep 23, 2003 | 08:55 AM
sluggslime's Avatar
sluggslime
Speedometer Jumping
well it seems I was misinformed... I replaced the cluster and the abs light is still on, the speedometer doesn't work and the transmission is shifting rough... I will replace the vss today and if that doesn't fix it then I will replace the abs speed sensor in the diff. The only thing to do if all else fails will be to replace the abs module. I will keep you posted.
Old Sep 23, 2003 | 09:39 AM
dblue351's Avatar
dblue351
Speedometer Jumping
It is going to be the VSS! I had the exact problems untill I changed mine. Then I shifted smoothly (When I had the auto) and abd speedo worked! The abs thing, well it is pretty common and some ont agree with my way of fixing it, but it still stops. I just pulled out the abs bulb. Plus I dont even have factory axles under it anymore, so there was really nothing else i could do to fix it.
Old Sep 23, 2003 | 01:46 PM
HILDJO's Avatar
HILDJO
Speedometer Jumping
tHANKS FOR ALL THE RESPONSES, i WILL PUT IN NEW VSS TOMORROW,I"LL LET YOU KNOW WHAT THE RESULT IS.
Old Sep 23, 2003 | 02:27 PM
sluggslime's Avatar
sluggslime
Speedometer Jumping
okay, I just went to the auto parts store and asked for the vss. They tried to give me a sensor that goes to the tranny with a socket for a speedometer cable.... the intstrument cluster doesnt use a cable, and neither does the e4od for that matter... it doesnt use one.. it is all digital. It took me awhile before I realized and asked for the abs speed sensor instead. I will install it tonight, and will cross my fingers...
Old Sep 23, 2003 | 02:37 PM
dblue351's Avatar
dblue351
Speedometer Jumping
The VSS (Vehicle Speed Sensor ) will either be in the transfer case or on I think 92+ on the top of the 8.8. rear end.
Old Sep 24, 2003 | 12:42 PM
HILDJO's Avatar
HILDJO
Speedometer Jumping
Okay same problem, they tried to give me a speed sensor with speedometer cable. I have ordered the other one. I still haven't found the thing yet on the Bronco, 93 5.0 cruise control. automatic. Anyone know exactly where that bugger is.
Old Sep 24, 2003 | 02:18 PM
sluggslime's Avatar
sluggslime
Speedometer Jumping
Well I replaced the abs sensor and it seems that it was part of the problem. When I took the old one out it was broken, part of the tip had been chipped out... by what is anybody's guess. I took it for a spin and the transmission shifts smooth BUT the Speedometer starts to jump from 40 to 70 mph range and the ABS light comes on soon after it starts jumping. Let me know if you encounter the same problem when you change yours, its located on the rear differential housing, top right looking at it from the driveshaft side. I am going to open up the differential tonight and see whats a muck. Hopefully cleaning it out and pouring some oil will fix it... I sure don't want to see any broken parts!
Old Sep 24, 2003 | 02:49 PM
frogger01's Avatar
frogger01
Speedometer Jumping
It's right where sluggs said it is on top of the 8.8 it will have a wire going to it.
Old Sep 25, 2003 | 07:29 PM
gale tyler's Avatar
gale tyler
Probably the exciter ring in the diff. May be warped. Good luck.
Old Sep 30, 2003 | 07:35 PM
br0nc0's Avatar
br0nc0
Well if you havent got it fix by now ther is a moduel under the dash that is your problem. I posted the part number on a post some time ago . But here is the part number f4tz-2c219-a i almost guarante that is your problem.
billy cooper
21
May 28, 2013 07:55 AM
Mopey
Mar 17, 2013 10:05 AM
ola1234
Dec 3, 2012 12:12 PM
countryboy6074
Feb 16, 2009 09:06 PM
southy7
Aug 25, 2003 11:40 AM
