1978 - 1996 Big Bronco
engine removal ?????
Old Sep 30, 2003 | 04:25 PM
ctford24's Avatar
ctford24
hi, i am removing the engine from my full size 88 bronco. would it be easier to take the engine out with the transmission attached or to unbolt it. when i put the new engine in, will i have to take out the tranny? it sits so damn high off the ground it is hard to get to all the bolts. i have removed engines before but i always removed the tranny at the same time. any help would be appreciated!
Old Sep 30, 2003 | 07:52 PM
tellico racing's Avatar
tellico racing
Much easier to unbolt the trans from the engine. Make sure to unbolt the torque converter from the flywheel or you will damage the tranny.
