Pulley belt postions
Old Jul 12, 2018 | 04:52 PM
harrythehack's Avatar
harrythehack
Hello, i am getting ready to put on my damper pulley, water pump pulley, alternater with pulley, and power steering pump with pulley. These parts are being installed on a 351 windsor. Not serpentine. I have to get a spacer damper for the damper pulley to make it line up. The damper pulley has three slots. Which slot on the damper should line up or be in alignment with water pump pulley? How should i measure? From the center of the water pump slot?
Old Jul 14, 2018 | 03:52 AM
1TonBasecamp's Avatar
1TonBasecamp
Back to the top. Curious too.
I have mine roughly set up, so might be able to help. But I'm pretty sure the water pump pulley is not the same one I pulled off originally. That or I'm missing a "sister" pulley that just fits in front of the other. I do seem to remember a two-piece setup coming off, but that was a lot longer ago than I'd like to admit.
Good luck.
Paul
Scott Yager
Sep 25, 2017 01:30 PM
Icefan71
1997 - 2003 F150
Apr 11, 2017 04:39 PM
OldFords
Apr 25, 2010 04:51 PM
Unglued
Oct 9, 2004 09:51 AM
beartracks
22
Sep 2, 2004 10:35 AM
