Aerostar Ford Aerostar
AWD transmission compatibility
Old Jul 10, 2018 | 02:26 PM
Car Guy's Avatar
Car Guy
For the AWD aeros... From the research I did, a 91 transmission will not work in a 95. I’m looking to know if this definitive or if there is a way around this. Reason being I came across a (basically) new high end rebuild of a trans from a 91. My van is a 95 and the trans is still going but slowly starting to wear out.
Old Jul 10, 2018 | 10:23 PM
RojoStar's Avatar
RojoStar
1994-95 was the approximate cutoff between vacuum controlled A4LD and the electronic 4R55E, requiring the newer engine control management box.
Old Jul 11, 2018 | 08:59 PM
Car Guy's Avatar
Car Guy
My 95 has the A4LD. When I search for Aerostar transmission info, years 90-91 and 92-95 is what I find for compatibility ranges.
Old Jul 11, 2018 | 10:21 PM
96_4wdr's Avatar
96_4wdr
do you have a vacuum modulator sticking out the passenger side of your tranny? if so, A4LD, which in 1995 V6 4.0L had many HD OEM upgrades over the years to take the torque of the 4.0L Cologne engine. tranny rated for approx 400lbs ft of torque after torque amplification of the motor torque by the TC. All shifts controlled mechanically by slider valves internally in tranny.
My '96 has the 4R55E with AWD 4.0L. all electronic shifts controlled by the PCM switching expensive solenoids in tranny.
Old Jul 13, 2018 | 10:09 AM
Car Guy's Avatar
Car Guy
Yes, A4LD for sure. I thought all 95 model year have the A4LD? I haven’t seen any cutoff dates when searching for 95 Aero A4LD transmissions.
If the reason 90-91 A4LD are not compatible with 92-95 is they are too weak, that shouldn’t be a issue with the A4LD I found. Although out of a 91, the rebuild was over $3K and done by a highly skilled rebuilder. He used heavy duty parts and did all the upgrades/modifications.
What I’m curious about is why 90-91 isn’t compatible with 92-95. Anybody have ideas?
Old Jan 17, 2019 | 11:32 AM
Car Guy's Avatar
Car Guy
Still looking for any thoughts on this. My van refuses to die, but eventually the day will come.
Old Jan 18, 2019 | 11:43 AM
Car Guy's Avatar
Car Guy
... or if anybody knows where I can find this information.
Old Jan 19, 2019 | 02:59 AM
99f350sd's Avatar
99f350sd
I have 2 trans for 96 awd...and the vans..for parts.
Old Jan 19, 2019 | 07:04 AM
Car Guy's Avatar
Car Guy
‘96 is the one year only electronic 4-speed transmission. ‘97 is also a one year only(for aeros) transmission, the electronic 5-speed.
Old Jan 19, 2019 | 07:38 AM
zenish's Avatar
zenish
im probably wrong but i think the 1991 trans was all internally controlled except the lock up converter.so it should work in a later van not hooking any wires except the lock up converter wires.the check engine light will probably stay on.oh and the speedo won't work.
Aerocook
Aerostar
Jun 8, 2010 04:50 PM
savagefan
Aerostar
Sep 11, 2009 12:46 PM
vanman802MS
Aerostar
Sep 25, 2004 06:13 AM
MrMeister
Jul 3, 2003 05:47 PM
