Aerostar Ford Aerostar
Tranny help PLS
Old Sep 23, 2004 | 08:45 AM
vanman802MS's Avatar
vanman802MS
Question Tranny help PLS
1990 3.0L A4LD 126K miles
On my 4th tranny!!!!!!
the Haynes book says all models thru 95 use the A4LD and I found an 87 w/ a blown motor, so I swapped trans. Overdrive plug was different. bad tranny has 2 sensors on the valve body and "good" tranny has 1.
Now when I reach 55 mph the tranny starts slipping, actually it "goes away"
once I drop back down to about 45 mph it kicks back in.
otherwise it's fine. great power curve and smooth shift, just no OD
thinking about swapping valve bodies or should I try the computer first?
thanx,
vanman802MS
Old Sep 23, 2004 | 03:18 PM
bear2x2's Avatar
bear2x2
Question
My guess would be that the over drive clutch is worn out. A word on the A4LD. This tranny is a decendent of the C5. What is a C5? the transmition that was designed for ........The PINTO This was a light weight tranny and Ford claims that the A4LD is tougher but seriously take a light tranny built for an 85 HP 4 bager add an OD put it behind an engine with 55 more HP and more torque in a 4,000 pound van and what do you get? Right a dead tranny.
Old Sep 24, 2004 | 04:33 PM
SgtJoe's Avatar
SgtJoe
I'm not sure which sensors or solenoids are on the good trans. I have rebuilt a couple of 1987 A4LDs and there is one TCC solenoid on the valve body. The Torque Converter Clutch (TCC) is not overdrive. It locks the torque converter up when the vehicle is crusing and not under load. The lockup will sometimes feel like a shift into overdrive.
Did you mis-match the torque converters? If so, it could be a problem. Keep the same torque converter with the same trans. If you did, the torque converter can be bad too. If the internal seals for the piston in the converter are bad, it will dump your transmission oil pressure causing a slip. If you can get a trans gauge and tap into the ports while you drive, measure the fluid pressure. Look for a sharp drop when you take your foot off of the pedal.
Good luck
Old Sep 25, 2004 | 06:13 AM
vanman802MS
Thanx for explaining the TCC. Don't know much "yet" about the guts of a tranny. Got a book on order.
Didn't change/swap TCs. I'll try the gauge and see what happens.
again, thanx for the info.
Semper FI n more to follow.
Thinlizzy13
Jan 8, 2016 05:23 PM
RojoStar
Aerostar
Jun 17, 2015 07:07 PM
vanman23
Jul 11, 2014 03:27 PM
vanman250
2004 - 2008 F150
Aug 19, 2008 05:29 PM
The Undertaker
Aerostar
Jul 30, 2003 01:47 AM
