Ujoint sizing questions??
Old Jul 10, 2018 | 09:44 AM
7.3 forever's Avatar
7.3 forever
Okay guys I’m wanting to finally have 4x4 since my 05 axle swap and I can find right conversion joint for front drive shaft to axle. So the plan is to just buy a new front yoke. I also just picked up a f350 front shaft and correct tcase yoke. Does anyone know what size ujoint is at the axle? Thanks in advance guys!!
Old Jul 10, 2018 | 09:03 PM
97-psd's Avatar
97-psd
If it helps, I believe I used the Moog 265 super strength for my front driveshaft joint
Old Jul 10, 2018 | 09:19 PM
7.3 forever
Well after fair amount more research I descovered that the 05 front axles have 1350 joint size at the yoke. The obs Dana 60 have a 1330 joint size after much searching I discovered that there’s a Moog conversion joint 459 is what I need to convert little cheaper than a new yoke. Hopefully this information helps someone in the future.
Old Jul 11, 2018 | 02:07 PM
96f250extcab's Avatar
96f250extcab
For what it's worth I go Spicer with my u joints whenever possible. I've heard plenty of people say moog USED to be a great company. Maybe their higher end products still are.
Old Jul 11, 2018 | 02:49 PM
7.3 forever
I usually only run spicer that’s what all my rear joints are now. But I couldn’t find the correct joint in a spicer so I’ll half to try my luck with Moog. But being that it’s on the front shaft and I really don’t use 4wd all that often I’m thinking it’ll be okay but if I do have problem I’ll just buy a 1330 yoke for the 60 and get a spicer joint.
Johnkimble
Jun 12, 2019 11:00 AM
mackdog
Apr 28, 2010 09:04 AM
fish_bulb
Feb 7, 2006 01:49 AM
4x4kinda girl
Jan 20, 2005 09:26 PM
