7.3 bucking at mid-high rpm
I have been trying to find a solution for this issue for quite some time. My truck bucks, almost like a hard miss, around 2500 rpms. The bucking gets less aggressive as the truck warms up, but is still bad if I put my foot down. It idles completely fine and if I stay under 2500 rpms you would never know there is anything wrong with the truck. Another weird thing it will do is if I am cruising on the interstate at about 75 mph and I suddenly let off the pedal for a second or two the truck will not accelerate when I put the pedal down again. Even if I floor the pedal when this is happening the truck will continue to not accelerate until about 60 mph it will blow a white cloud of smoke and accelerate again. When this happens the check engine light comes on for about a minute then goes off after regular driving and the truck does not store the code.
I have already replaced the following:
IPR
ICP
All fuel pumps
CPS
Fuel filter
I am trying to avoid replacing the injectors, but what is the best way to test them if this only happens at higher rpm? Has anyone ever run into this problem before? Could it be an electrical issue rather than fuel? Could it possibly be the IDM? Any help on this issue is much appreciated.
Thank you!
IPR
ICP
All fuel pumps
CPS
Fuel filter
Thank you!
Hmmm ok maybe I can download something to my computer and hook up to the OBDII and try to find the code that way. That wouldnt cause the bucking though, would it?
Fuel filter still looks brand new, I just went out and checked it.Do you think I should try rebuilding the injectors first?
Injector rebuild on a HEUI system should really be left to the professionals. Lots of tolerances and tiny parts that need to be just right.
I was referring to the exterior o-rings of the injectors, the ones that seal between the head and the OD of the injector itself. Those can be done by the average shadetree guy fairly easily, there are plenty of vids on youtube or writeups with great pictures on this forum and others.
Thanks for giving me some feedback!
The check engine light is probably trying to tell you what the problem is.
You can read the codes if you buy an OBDII adapter that works with SAE J1850 PWM. Torque and Forscan apps are mentioned in this forum. I got the PC version of Forscan.
https://forscan.org/forum/viewtopic.php?f=4&t=6142
This link talks about adapters and why the cheapest ones probably won't work.
I got the OBDlink MX BT off eBay for $fifty-something. It has been reliable. It's $79 new on Amazon, etc.
What year truck are we talking about?
I appreciate all the help!
Gotcha thanks for recommending a good brand. I’m going to try to get these codes read soon.
IPR
ICP
All fuel pumps
CPS
Fuel filter
Thank you!
IPR
ICP
All fuel pumps
CPS
Fuel filter
Thank you!
I used one from international. I’ve read up on the problems with the off brand CPS. I guess I could try one from a dealership too Incase I got a faulty one.
