Please help!
Old Jul 6, 2018 | 01:34 PM
scsjones's Avatar
scsjones
Please help!
I was driving along in my 1976 f350 390 np435 4 speed, and all of a sudden I can't down shift to 2nd, it only grinds. If I am completely stopped it goes in just fine. I have adjusted my clutch linkage with no luck. I just want to see if anyone knows what the problem could be. Possible broken clutch finger?
Old Jul 6, 2018 | 01:47 PM
WentzMetalWorks's Avatar
WentzMetalWorks
Sounds like a trashed syncro.
Old Jul 6, 2018 | 03:05 PM
mark a.'s Avatar
mark a.
I second that, that's about all that would cause it to grind. I had the same problem and it didn't look all that bad but in the end that's what was wrong.
Old Jul 6, 2018 | 04:23 PM
FuzzFace2's Avatar
FuzzFace2
Me 3rd but for S&G check the lube level being low might cause that.
I think it takes 80w-90 gear oil.
Dave ----
Old Jul 6, 2018 | 05:44 PM
scsjones's Avatar
scsjones
Dave ----
Lube is full and looks like new.. First to second does great, but third to second doesnt
Old Jul 7, 2018 | 05:10 AM
User 71024's Avatar
User 71024
try double clutching, if it works then it's the syncros.
Old Jul 7, 2018 | 07:51 AM
WentzMetalWorks
Exactly! Matching your rev's should do the trick if the syncro is bad.
Old Jul 7, 2018 | 11:33 AM
LiveFrom1977f150's Avatar
LiveFrom1977f150
I have to be going uncomfortably slow in 3rd before 2nd takes. Or itll grind just the same as you describe. Im going to consider upgrading to a 4spd with overdrive over the next cpl of years. Ive yet to drive a 4spd granny low that wasnt jenky in its downshifting and didnt have a sloppy loose shifter.
Old Jul 7, 2018 | 12:14 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
NP435 has nylon inserts on the shift forks. 1/2 use different inserts than 3/4.
Shown as 7C430 in pic:
kh0432
15
Jan 27, 2018 01:04 PM
Stephen67
15
Jul 21, 2011 02:00 PM
1=2
Feb 16, 2009 12:02 PM
RhinoScores
1983 - 2012 Ranger & B-Series
Nov 30, 2006 10:10 PM
jernut
Nov 16, 2005 08:44 AM
