Feel like my truck is lacking power but unsure
I have a 93 ford f150 with the 5.0 and around 240k miles on it. I have had it for more than a year was wondering were they designed to not have power cause from a dead stop on any surface i cant get the tires to spin. The truck shakes when it shifts down to a lower rpm at 30 mph or above
Unless someone swapped that 9" rear axle in, your truck left the factory with 8.8". Check the label on the driver side b-pillar for the Axle code. Post it, we can tell you what gear ratio the truck left the factory with.
Yes, these trucks left the factory with very little power. I think in the 200HP range? If you are running larger tires than stock that also magnifies that a truck with a 5L engine is very under powered.
Fuel filter?
Ignition coil?
Transmission fluid?
Clogged catalytic converter?
There are many things it could be.
bubbareitz
07-24-2015 03:52 PM
zach_barrow
05-17-2005 01:25 AM
