Feel like my truck is lacking power but unsure
Old 07-06-2018, 08:10 AM
Kyndl Baber's Avatar
Kyndl Baber
Kyndl Baber is offline
I have a 93 ford f150 with the 5.0 and around 240k miles on it. I have had it for more than a year was wondering were they designed to not have power cause from a dead stop on any surface i cant get the tires to spin. The truck shakes when it shifts down to a lower rpm at 30 mph or above
Old 07-06-2018, 08:30 AM
FORDF250HDXLT's Avatar
FORDF250HDXLT
FORDF250HDXLT is offline
What's the gear ratio in the rear?
Old 07-06-2018, 11:45 AM
Jerod Bahrs's Avatar
Jerod Bahrs
Jerod Bahrs is offline
should be 3.55. Most are unless it was swapped
Old 07-06-2018, 11:55 AM
Kyndl Baber
All i know is its the 9 inch
Old 07-06-2018, 12:09 PM
rla2005's Avatar
rla2005
rla2005 is online now
Received 1,179 Likes on 931 Posts
Unless someone swapped that 9" rear axle in, your truck left the factory with 8.8". Check the label on the driver side b-pillar for the Axle code. Post it, we can tell you what gear ratio the truck left the factory with.
Yes, these trucks left the factory with very little power. I think in the 200HP range? If you are running larger tires than stock that also magnifies that a truck with a 5L engine is very under powered.
Old 07-06-2018, 01:06 PM
LSCRX's Avatar
LSCRX
LSCRX is offline
You should have a sticker on the drivers side door jamb like this...
See what the code for the axle is, mine is 18 for "3.08", 19 is 3.55 if it's not one of those... post it, and I'll tell you what it means :P
Old 07-06-2018, 01:12 PM
LSCRX's Avatar
LSCRX
LSCRX is offline
For the record, I have a '95 F-150 with the 5.0, and the "worst" rear end (3.08)... and it will burn tires if I floor it on dry pavement. So if your truck was healthy, it should be able to do the same... i'm guessing you have something holding you back.
Fuel filter?
Ignition coil?
Transmission fluid?
Clogged catalytic converter?
There are many things it could be.
Old 07-06-2018, 07:54 PM
Kyndl Baber
Thank you all for the help i will have a picture of the sticker here shortly but do any of you know the shcking problem at all
Old 07-06-2018, 08:55 PM
Robert Long's Avatar
Robert Long
Robert Long is offline
Without knowing exactly what you have,there's no way to determine lost power or over expectations.
Cheryldale
2017+ Super Duty
41
12-02-2018 01:02 AM
bubbareitz
07-24-2015 03:52 PM
RedRage
2004 - 2008 F150
07-14-2005 07:15 PM
zach_barrow
05-17-2005 01:25 AM
Big bad redneck
1997 - 2003 F150
11-25-2004 10:50 AM
Quick Reply: Feel like my truck is lacking power but unsure
