360 block-67-427
Old Sep 21, 2003 | 09:26 PM
390fourby's Avatar
390fourby
360 block-67-427
I pulled a 360 out of a 72 f-250 camper special and found a weird casting number. On the rear of the block behind the flexplate it has 67-427 casted on it. I thought this was kinda weird I measured the bore and stroke and it is a 360. There are no other numbers on the block besides the 352 on the front and a casting date. Another thing that I noticed were some vertical lines cast on the LH side, they are about 1" wide 3" high and protrude 1/8", is that just a 360 thing, my 390 and 428 blocks dont have the lines.
Old Sep 30, 2003 | 09:37 PM
ford man mike's Avatar
ford man mike
i think its gotta be bud cause i got 2 390s and a 534 and they dont have those lines did you look under the the oil pan they say the right numbers are on the iside of the block
Old Sep 30, 2003 | 09:58 PM
dinosaurfan's Avatar
dinosaurfan
360 block
3904x, the block you have is a normal 360. It says '66-427' on the back half because Ford used the back blate for a 427 on the mold when they poured your block. Lots of blocks that aren't 427s have that on the back. I really think that the assembly line workers used whatever mold plates were handy at the time. The ribs on the side are from where the molds were modified because they were wearing out. The important part is what the cylinders are like, yours are probably the ordinary 360/390 style. DF
pittmick
Jan 27, 2010 02:06 AM
actioncam1
Dec 8, 2005 04:53 PM
mike390
Aug 3, 2005 06:44 AM
ilikefordtrucks
Sep 15, 2004 04:23 PM
original67
May 19, 2004 10:10 PM
