Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
A/C Compressor Replacement
Old Jul 5, 2018 | 06:49 AM
MyFordEscape's Avatar
MyFordEscape
Exclamation A/C Compressor Replacement
Hi guys. Little help would be appreciated.
I am replacing A/C Compressor and Receiver Drier with all O-Rings. I am not sure if I should put OIL in Compressor only or in Compressor and in Receiver Driver?
Thanks for your help.
Old Jul 11, 2018 | 09:00 AM
ugmw177's Avatar
ugmw177
The proper way is to remove the old receiver and then pour out any oil it has in it into a measuring cylinder. Put new oil in the new receiver equivalent to the amount you measured from the old part.
Old Jul 11, 2018 | 02:59 PM
projectSHO89's Avatar
projectSHO89
Even better is to completely flush the old system and then add the full amount of the oil back into each component according to the service manual. If you just put back in what you drain out as suggested above, you're usually going to end up light on the oil.
Be aware that replacement compressors my come with or without oil in them. I've gotten ones that said they were filled and they weren't so check it before installing.
MeatHook
Sep 20, 2013 06:10 PM
daveya48187
1983 - 2012 Ranger & B-Series
Jun 15, 2013 07:06 AM
mchild
Jul 5, 2009 06:20 AM
Danger_Dave
Oct 27, 2008 01:06 AM
kc7smo
May 22, 2006 09:16 PM
