Passenger side door lock unresponsive
Old Jul 2, 2018 | 09:14 AM
jrsharp21's Avatar
jrsharp21
4wd Low
The door lock on the passenger side is unresponsive to the key fob or the unlock button on the drivers side door. I have to push the key fob multiple times to get the door to unlock/lock. This morning I think I pushed the button on the drivers side door 10 times to get it to unlock. Any ideas what could be going on? I switched key fobs to make sure it wasn't the fob or battery and got the same results.
Old Jul 2, 2018 | 10:20 AM
projectSHO89's Avatar
projectSHO89
It would help if you explicitly identified your truck.
On my 01, I had both actuators go out at about the same time a couple of years ago. Thought it was a control electronics problem since the timing appeared to be the same when I noticed the problem. Tore into the dash, check the operation of the relays and saw that they were working normally. Checked wiring and finally opened up the door panels and tested at the actuator connectors and everything was normal up to there. Both actuators had failed... Dang, what were those odds? Put in Dorman replacements from RockAuto, still working. Note: I had to do the aluminum foil trick on both of them when I bought the truck back in 2011. Both had bad thermal devices back then.
Old Jul 2, 2018 | 10:54 AM
jrsharp21's Avatar
jrsharp21
4wd Low
It is a 2013 Ford 150 Crew Cab 4x2
old yella
Jan 22, 2019 03:28 PM
20015.4f350
Nov 11, 2015 11:37 PM
mark6x43
Sep 22, 2009 02:59 PM
98greensi
2004 - 2008 F150
May 15, 2009 05:54 PM
