Help with P0299
Old Jun 30, 2018 | 10:24 AM
Hunter40's Avatar
Hunter40
Help with P0299
I’ve had a recurring P0299 code for about the last 35,000 miles. I’ve had the truck in the Ford garage three times already for it and they can’t find any problems. Currently the engine light is on and P0299 is showing on my scanner.
Truck: 2012 F350. 112,000 miles with extended warranty to 135,000. Engine and exhaust are stock with no modifications.
What I’ve done: checked the CAC for any leaks or breaks. Can’t find any. When I took it apart to check for cracks I was surprised at the oil and gunk built up inside. I’ll attach a photo so you guys can tell me if it is normal.
I have another appointment scheduled with Ford, just trying to look for solutions since they have been unable to find anything.
Old Jun 30, 2018 | 03:29 PM
Just Strokin's Avatar
Just Strokin
Sounds like you have a loss of boost pressure. Maybe bad o-ring on the cold air tube or a crack you can't see or even the inter cooler is leaking.
From the MY2015 OBDII.
Underboost Monitoring
The underboost monitor works in a similar fashion to the overboost monitor by comparing the desired vs. actual
measured boost pressure while in a specific range of closed loop boost pressure operation. If the boost pressure
governor deviation is greater than the calibrated threshold for 7 seconds, a fault is detected and the P-code is set.
The closed loop monitoring window is defined as any inner torque above 50 nm, and any engine speed above
1500 rpm. The threshold limit is wider for the underbooost monitor due to transient boost system response,
compensation for boost pressure lag, and short term (1-2 second) momentary torque truncation when air path
torque is kept high, but fueling is limited for component protection.
This diagnostic will detect a gross air path leak such as the turbo discharge or CAC discharge tube being blown off,
major pre-turbo exhaust leaks, or a turbo slowly responding or stuck in the open VGT position.
Underboost Monitor:
DTC - P1247 - Turbocharger Boost Pressure Low
DTC - P0299 – Turbocharger/Supercharger “A” Underboost Condition
Monitor Execution Continuous
Monitor Sequence None
Sensors OK ECT, MAP, MAF,
Typical Monitoring Duration 7 sec
Old Jun 30, 2018 | 04:06 PM
kper05's Avatar
kper05
I didn't have a code but could hear the air leak. It was the CAC duct, cracked at both ends where the clamps are. BC3Z-6F073-A
This was around 95k. You have less oil residue.
Old Jul 2, 2018 | 11:07 AM
jimmystoys's Avatar
jimmystoys
Cold side, CAC tubing, well known for failing. I decided to upgrade mine. Actually bought it when on holidays and on the way home up our notorious Coquihalla Hwy blew the stock plastic tube. Had to jump into the back of the truck and unpack he new CAC kit and install part of it with a lot of tuck tape to get me home. Little unnerving fixing your truck on the side of a very busy highway with a trailer connected!
Old Jul 4, 2018 | 08:09 AM
Hunter40's Avatar
Hunter40
Solved...I think.
I reexamined the cold side cac tube and found the o-ring showed clear signs of blow by on the bottom portion. The ring also was malformed at this spot whichh didn’t let it mate properly to the metal surface.
I bent the plastic o-ring back down and reinstalled it so it was on tight. The code has not reappeared and the truck is building a full 20 lbs of boost now.
A new cac tube will be placed on the truck for a permanent fix.
Thanks all for the help.
Hunter40
CousinCarl
May 25, 2017 06:42 AM
Oldanvilyoungsmith
19
Apr 27, 2017 07:16 AM
tjmike
18
Jun 18, 2016 08:44 PM
60RatRod
17
May 6, 2010 02:20 PM
rat49f6
35
Aug 24, 2009 03:07 PM
