1966 Door Tag
Old Nov 2, 2010 | 05:48 PM
shanekbms's Avatar
shanekbms
1966 Door Tag
I have a 1966 Ford F100, 2wd, w/a 352 V-8, 3spd. manual. I need help decoding the door tag to see whats original and whats not.
F104K849062
129 M F100 581 C 17
05000 172 4000 548644
Thanks for your time.
Old Nov 2, 2010 | 10:04 PM
OldHarley's Avatar
OldHarley
F10AK849062
129 M F100 E81 C 17
F10 = Truck series code - F100 2WD
A? = engine - 240 cu. in. 6 cyl or if Y = 352 cu. in. V8 (you say it is a 352)
K = Kansas City Assembly Plant
849062 = Assembly date code - Built April 1966
129 = wheelbase - long bed
M = color - Wimbledon White
F100 = Model code - 5000 GVW
E81? = Red Crush Vinyl/Red Cody Pattern Woven Plastic interior/Custom Cab
C = 3 speed manual light duty transmission
17 = rear axel ratio - 3.25
Last line is GVW, HP rating at given RPM and DSO (dealer special order code)
Lastly, WELCOME TO FTE!!
Old Nov 3, 2010 | 05:14 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
F104?K849062 /129 / E81 / C / 17 / 05000 / 172 / 4000 / 548644
Welcome to FTE
The 4th digit of the VIN is the engine code.
It's not a 4 (no such thing), it's a Y since the 172 net HP @ 4,000 RPM matches the 352 2V.
129" Wheelbase. 129 does not decode to anything inre to a pickup bed...just the wheelbase only.
E81: E = Red Crush Vinyl & Red Cody Pattern Woven Plastic (this refers to the seat upholstery) / 81 = 81B Custom Cab.
C = Ford type 3.03 3 Speed Manual Medium Duty Transmission. The Light Duty was only used with the 240 I-6.
17 = Ford 9" Rear Axle / 3.25-1 / non Limited Slip / 3,300 lb. Rear Axle Capacity.
5,000 lbs. Gross Vehicle Weight Rating.
548644:
54 = Omaha NE Ford District Sales Office, where the original selling dealer ordered the truck from.
8644 = Domestic Special Order number. The truck was special ordered by the original purchaser, not "bought off the lot."
Old Nov 4, 2010 | 06:12 AM
shanekbms's Avatar
shanekbms
Thank you
Thank you time and knowledge. It was greatly appreciated.
1966f100ranger
13
Aug 10, 2016 01:27 PM
Sb1
Oct 3, 2015 01:00 PM
dreadedwind
Sep 24, 2015 07:55 PM
dads1966
Sep 1, 2013 01:30 AM
Mercmeister
Oct 8, 2011 03:12 PM
