sounds like the electrical plug for the light switch is burned. common problem with the 88 to 91 trucks, so i would imagine it is also a problem with the 92-97 trucks. repair is a new switch and plug.
Yeah, with the way its wired, it's no surprise its finally went.
Mine are a bit brighter, nothing HUGE. Was it worth it? Yes, takes the load off the headlight switch. That alone works it to prevent a potential melt down in the cab. Brighter lams are a byproduct. I still have junky headlights, need to swap them and I am sure I will notice more of a difference.
