I bought some 20x9 +20 offset wheels for my 2018 CCSB F250. I also ordered two sets of tires Nitto Ridge Grappler tires one in 37x12.50r20 and one in 35x12.50r20.
Since I had already intended to level my truck, I am going to try to fit the 37's on my new 20x9 wheels first. If I can't stand the finished product, I send those back and use my 35s, no harm no foul.
I've seen some posts saying 20x9 +20 offset will work with no rubbing, but have also heard some conflicting stories. Can I get some input from someone that has tried this setup? I saw a YouTube video of a Ford dealership selling a brand new F250 with a 2.5" level and 37's with a +20 offset wheel which leads me to believe it was doable.
I may be old school but I have no idea why you youngsters insist on using offset instead of back spacing. Offset is a relative measurement to the width of a rim, while back spacing is a measurement from the mounting surface to the inside edge of the wheel. BS is what you need to be worried about when it comes to fitment (rubbing issues). Who cares how far the rims stick out, the only reason to care is aesthetics. On that note, the recent trend of low profile and wide tires that stick out way to far is not appealing to me. I really hope this fad fades soon. Just had to add that last part.
offset is actually the difference between the mounting surface and the *center* of the wheel (width-wise), regardless of the overall width. a 0 offset has the surface dead centered in the wheel. the +40 stock is 40mm towards the outside of the wheel. I think people use it because wheel manufacturers use it. you can always calculate backspacing using offset, if you prefer that. This image explains it well, IMO:
I agree on the ugly tire-sticking-out problem. Whoever convinced people that's a thing they should do to their trucks? I actually saw some youtube video the other day that showed a meet of guys who clearly spent thousands upon thousands to modify their trucks... massive lifts, super complicated suspensions... giant wheels with low profile tires. How can you do anything offroad with no sidewalls? what's the point of all that ground clearance if your tires are completely useless anywhere but the street? ugh.
offset is actually the difference between the mounting surface and the *center* of the wheel (width-wise), regardless of the overall width. a 0 offset has the surface dead centered in the wheel. the +40 stock is 40mm towards the outside of the wheel. I think people use it because wheel manufacturers use it. you can always calculate backspacing using offset, if you prefer that. This image explains it well, IMO:.
You are correct however, the offset alone does not tell you where the inside of the wheel will be in space, you have to know the width of the rim before you can figure that out. The placement you need to know for fitment is where the inside edge of the rim/tire will be. I stand by my point. BS tell you this in one easy measurement, while offset you have to know two measurements and do more math....
Edit: just had a thought, maybe that is why they have their wheels sticking so far out. They only know offset and cannot figure out where the rim will sit,therefore they push them out to be safe so the don't touch the suspension
haha maybe it is
FWIW I totally agree with your logic, just wanted to be sure we were all speaking the same language. Also, when i bought the last few sets of wheels (for my fun car and my trucks), the manufacturer only listed offset, so I had to calculate the backspacing myself. it wasn't that difficult though. once you know you're going to have a 9" wide wheel, then you are looking at apples to apples comparisons when you consider the various offsets. it also helps you visualize how "deep dish" that wheel might be. For example, on my '98 cobra, I wanted to squeeze 305 tires on there so I knew I needed a 10" or 10.5" wide wheel. Not only did I want to avoid contact with the exhaust and the quad shock, but I also wanted to bring the tires out closer to flush with the fender. That body style has hips, and IMO looks anemic with the rear wheels so far recessed. having the offset measurement allowed me to get both backspacing and frontspacing, so I found the perfect fit
I'll say this- I went with 35's on that rim size. I ordered my truck with the factory mud flaps and they rub a teeeeeeeeny bit with the wheel about 1/2 way to lock. Not enough to bother me, but if I had 37's, it would definitely be an issue. In other words, if you have mudflaps, you better grab a 6 pack and dremel.
