Sponsored by: Real Truck
Looking for Tires Need Help Please
Old Oct 7, 2010 | 12:34 PM
mallory9's Avatar
mallory9
Just bought a set of 18x9 rims with 4.5" backspacing. Wondering what would be a good tire for this combo, on a 06 f250 fx4. Looking at the 325/65/18s Nittos or the 305/65/18 BFG All Terrains.. Will both work without rubbing? Dont want to order either one without some input. Thanks in Advance.
Old Oct 7, 2010 | 12:45 PM
PERFORMANCE RED's Avatar
PERFORMANCE RED
With 4.5" BS The wheels will be sticking out of the wheel wells pretty far. 325/65 tires will be about 13.5" wide. Without a lift of some kind they will most likely not clear.
The 305/65's should fit with the stock wheels but I am not sure with the BS you have on the 18x9" wheels.
Old Oct 7, 2010 | 01:15 PM
mallory9's Avatar
mallory9
The truck looks to have a leveling kit in it, if not Ill put one under it no problem there. Another option is a 305/70/18.. this may fit? Anything you would suggest for it, the current tires are 275/70/18 on stock wheels, which work out to around a 33x10.5, and they seem to have a ton of room for a couple more inches.
Old Oct 7, 2010 | 01:45 PM
PERFORMANCE RED
Well I have 35x12.50x18 tires on my F350 with snowplow package but I also have 5.98" of back space on my wheels. I have no rubbing issues at all. I think the issue you are going to have is the backspace on the wheel you have, 4.5" With the wheels sticking that far out of your wheel well I am not sure what will rub and where and what size tire is the biggest you could go.
Old Oct 7, 2010 | 02:30 PM
rickf92592's Avatar
rickf92592
They might rub a bit on the back of the inner fender liner (at full-lock) which can be tie-wrapped back and out of the way.
Oh, and look at the Yokohama Geolander ATS before you buy.
Great tire!
(But I'm biased because they're a sponsor)
Old Oct 7, 2010 | 06:30 PM
Will Bite's Avatar
Will Bite
I have a 2006 cc fx4 f250 with Toyo m/t 33x12.50lt18 on moto metal 18x9 fit great with no rubbing. Tires look great.
Old Oct 7, 2010 | 06:32 PM
Will Bite's Avatar
Will Bite
