Rear bumper support
Old Jun 19, 2018 | 02:39 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Question Rear bumper support
Anyone have any good ideas about reinforcing the rear bumper (standard 4" square) that are common on trailers today?
My wife and I would like to bring our bicycles with us when we go out and about. Although, we are not interested in the front hitch bike rack that you see from time to time, I don't want to put them on the front of the truck either due to visibility concerns.
I have thought about bike racks that mount to the frame and then reach out past the bumper, but not sure if that is the right answer. I have seen them on E-Trailer and the like.
I have thought about taking the trailer to a welding shop and having them weld steel straps that cross the bumper and reach into the frame, kind of like a cantilever effect.
I just found this product and think that it should be considered.
Amazon Amazon
Open to experiences and ideas that someone may have come up with that I have not yet thought of. Thanks
Old Jun 19, 2018 | 07:50 PM
BleedMichigan's Avatar
BleedMichigan
Safety Struts work well if your bumper is only held on by a weld or two.
Old Jun 19, 2018 | 08:09 PM
Sous's Avatar
Sous
FTE Emeritus
The welds are the typical ones on the rear of the bumper which is toward the camper. There are welds in the vertical seams and one across the top.
I am going to look around a bit more but these look promising.
Old Jun 19, 2018 | 09:49 PM
BleedMichigan
Some angle and self tapping screws does a similar thing. I had a friend who had installed the safety struts and the welds ended up breaking on the bumper, Saved the bikes. Reworded the bumper and left the struts on just Incase. It’s good insurance and the price isn’t bad for a bolt on solution.
Old Jun 20, 2018 | 10:23 AM
superrangerman2002's Avatar
superrangerman2002
I relocated my spare to under the coach and replaced the bumper with a frame mounted hitch.
I wired in a 4way connection. Now I can bring 4 bikes safely or tow my enclosed trailer.
Old Jun 20, 2018 | 11:41 AM
Sous's Avatar
Sous
FTE Emeritus
Where did you mount the spare tire to, under the camper with a BAL system or retractable cable?
Old Jun 20, 2018 | 01:13 PM
superrangerman2002
Sorry about that, I should have been clearer. Yes I am using the BAL system. It’s easy to install and really simple to drop and check tire pressure. I have it mounted just in front of the trailer axels.
Just relocating that 70 to 100 lbs of moment arm stress will help your existing rear bumper.
Bal spare carrier
Old Jun 20, 2018 | 03:00 PM
Sous's Avatar
Sous
FTE Emeritus
We ordered the bumper supports and have not yet decided on what to do about the bike rack or the spare tire. We feel the extra support will be good for the bumper regardless of if we leave the tire there or install a bike rack. We use the bumper as a step up to get to the first ladder rung, so the supports should provide a long life for the factory welds.
Not sure about putting the spare tire under the trailer because we like to be off the beaten path and get away from the concrete and asphalt as much as possible. Our favorite place to camp so far is up in the NC mountains up a forestry service road and ground clearance is a must.
Old Jun 20, 2018 | 04:50 PM
superrangerman2002
I’ll snap a picture of my spare when I get home. I have mine fairly close to the axel for similar reasons.
I worry way more about tail drag than I do about hitting my spare tire as it currently mounted in some of my limited off-road boondocking on section lines.
Old Jun 20, 2018 | 04:55 PM
Sous's Avatar
Sous
FTE Emeritus
A picture would be be great, thank you for the offer and your time.
Old Jun 20, 2018 | 05:42 PM
dirthawg's Avatar
dirthawg
This guy did a decent job, should hold up well if you have the tools.
Old Jun 20, 2018 | 06:12 PM
superrangerman2002
I tried to take a few pics from different angles.
Pass front looking rear. See how the stairs are almost lower than my spare?
Between jacks looking back.
From Pass side I mounted between my fresh drain and low points. I have the pull out on the passenger side so I don’t have to take as much risk on a highway.
Removal is super easy. Just simply unscrew the ****( it has a cotter key) and grab both hoops and pull. Since the other end is mounted you only have to handle 1/2 the weight. Remove tire and replace with bad tire and your done.
niko20
May 15, 2021 07:35 AM
nortonrider
18
Nov 21, 2011 10:53 AM
StanleyZ
6.4L Power Stroke Diesel
Oct 28, 2011 10:34 PM
CraigK
Dec 16, 2008 11:52 PM
OldBrown82
All Things Towing
Jan 1, 2007 08:59 AM
