Noob question regarding rear bumper
Old Dec 16, 2008 | 10:18 AM
CraigK's Avatar
CraigK
What kind is this and why change from the original? Is it because someone added a hutch and it wouldn't work with the old bumper? How did Ford do it with the original bumper?
Thx,
Craig
<a href="http://s180.photobucket.com/albums/x301/DcraigTA/?action=view&current=DSC_0429.jpg" target="_blank"><img src="http://i180.photobucket.com/albums/x301/DcraigTA/DSC_0429.jpg" border="0" alt="Photobucket"></a>
Old Dec 16, 2008 | 10:30 AM
guitarnik's Avatar
guitarnik
just an aftermarket bumper
Old Dec 16, 2008 | 12:35 PM
madpogue's Avatar
madpogue
Right side is higher. WAG - previous owner got rear-ended, destroyed original bumper, bent right side bracket/extension, owner just slapped an aftermarket bumper onto bent mounts.
Old Dec 16, 2008 | 12:50 PM
awilsonF250's Avatar
awilsonF250
receiver looks crooked too; going with the rear-end damage theory too. Crawl around under the rear and see if anything looks out of alignment. It also might affect the way the bed sits on the frame?
Old Dec 16, 2008 | 08:39 PM
Fox_Racing's Avatar
Fox_Racing
looks like a mr pick up step bumber with around 6 inch drop, the the reciever mounted to it? does it say mr pick up with a load rating on that little tag? did a farmer or rancher own it before you?
Old Dec 16, 2008 | 08:42 PM
CraigK's Avatar
CraigK
Could have been a rancher. It's for sale here in California. It used to live in Arkansas and then Oklahoma. I'm going to have a look on Thursday. It was on Ebay last week but there was a problem so the buyer was let out of the deal.
Old Dec 16, 2008 | 08:45 PM
fordguy300's Avatar
fordguy300
the lean could be a messed up leaf spring
mine has a broken leaf and sits just like that
Old Dec 16, 2008 | 08:49 PM
CraigK's Avatar
CraigK
I didn't even notice the lean, I thought it was the pushed up right side.
So what do you all think?
1996 Ford F150 Truck V8 Supercab XLT 4x4
Old Dec 16, 2008 | 09:06 PM
Fox_Racing's Avatar
Fox_Racing
looks pretty good has 3.55 ls rear thats a big plus
Old Dec 16, 2008 | 09:11 PM
danr1's Avatar
danr1
Yea that bumper is bent, note the creases in it both sides and it is pushed up on the right end. Both ends are bent/pushed in, has a slight upward twist out at the ends because of it.
The receiver hitch and box look straight, truck looks straight. Looks like its all in the bumper. To make it look a little better hook a chain to the lower outer corner of the bumper and then to a tree and pull it back out, then loosen up the mount bolts a little and adjust it so its even.
However even when done with all that the bumper itself will never look flat and true again, that flat smooth surface on it is a dead giveaway area for any and all flaws.
Old Dec 16, 2008 | 09:51 PM
probie's Avatar
probie
Thats the same bumper I have, but it came from ford with it.
Old Dec 16, 2008 | 11:46 PM
madpogue's Avatar
madpogue
Bumper issue (front also) is mentioned in the Craigslist page; that's honest of her. "Iffy Lube" sticker is a caution; too bad she let them lay their hands on this vehicle.
Old Dec 16, 2008 | 11:52 PM
CraigK's Avatar
CraigK
She does mention the bent bumpers, I was just wondering why the different looking rear bumper. She said she got it that way from the PO. I'll have a close look on Thursday.
I could probably change the mounting bracket and fix the front, and I'd put the original style back back on the rear.
