window removal
Old 06-18-2018, 07:03 PM
old yella's Avatar
old yella
old yella is offline
window removal
Working on my 49 f1 and I cracked the drivers side window. Ordered a new one actually two just in case. Anyone willing to enlighten me on the correct procedure of removing the glass ? I only have two chances or else I'm reordering. That's how you get experience right ? Thanks !
Old 06-19-2018, 05:33 AM
FortyNiner's Avatar
FortyNiner
FortyNiner is offline
Welcome. Do you have the original style glass?
Old 06-19-2018, 08:07 AM
gogoat's Avatar
gogoat
gogoat is online now
I replaced the felts around and under the window on my 49 F1. I found you have take the regulator and divider bar out. There is a top screw at the top of divider bar to take out. Take your time and it will go. Hope this helped
Old 06-19-2018, 08:38 AM
old yella's Avatar
old yella
I have the new glass from lmc so it is the original style. I noticed the window when rolled down comes off the track slightly so maybe adjusted is needed before replacing the glass. If there is adjustment, I guess I'll find out. The bar for the door handle seems to be bent and I cannot lock the drivers door . Which is my next project putting in a lock on the passenger side, the hole is there with a plug so I assume this will be possible. Good thing I have it in the garage , I have a feeling this is going to take awhile !
Old 06-19-2018, 08:44 AM
old yella's Avatar
old yella
gogoat, by divider bar you mean what ? I do not see anything called that.in the catalogs. Are you referring to the horizontal bar that holds the window ?
Old 06-19-2018, 04:42 PM
abe's Avatar
abe
abe is offline
One Meadow Green Owner
Received 2,616 Likes on 1,456 Posts
Yes, that is known as the division bar. I think you need to buy the shop manual. You'll find how to do all sorts of things.
Old 06-19-2018, 07:32 PM
52 Merc's Avatar
52 Merc
52 Merc is online now
Received 2,451 Likes on 1,398 Posts
Yella, I agree with Abe you could find a lot of learning material in the factory shop manual. There's a repair procedure for just about every part of your truck in there. It's available in paper and CD formats. Here's a link to one of many available sellers.
https://www.ebay.com/p/Ford-1949-195...5637972&chn=ps
As a point of clarification, the division bar is the vertical divider between the vent window and the door glass in the window opening of the door.. The horizontal part I believe you referred to is the lift channel at the bottom of the glass, which attaches to the regulator.
Old 06-19-2018, 09:21 PM
abe's Avatar
abe
abe is offline
Uh oh. I made a dumb mistake. He said horizontal and I'm thinking vertical. Sorry....
Old 06-20-2018, 07:50 AM
old yella's Avatar
old yella
I will look into that shop manual however my 49 is not stock so most of it will not pertain to my truck. Short of the body everything else has been updated power steering ,disc brakes, 5.0 etc.
Old 06-20-2018, 08:11 AM
gogoat's Avatar
gogoat
Sorry it is the vertical division bar I was referring to.
mkrog
10-29-2011 07:07 AM
beezervs
08-29-2011 10:09 PM
hutchie
01-16-2011 02:13 PM
53ford
05-07-2006 12:10 PM
tgregoire
04-23-2002 11:54 AM
Quick Reply: window removal
