Speedometer drive gear
Old Jun 14, 2018 | 04:09 PM
Pepsford's Avatar
Pepsford
Hey guys quick question hopefully it's an easy one, trying to order my speedometer drive gear that connects to my speedometer cable... the book says to count the number of teeth and my options are 19 20 21 and 22 teeth. I'm assuming they are talking about the teeth in the transmission. This is what I see only 6. Any help would be great. I'll also mention is a 53 fordomatic.
Old Jun 14, 2018 | 04:20 PM
52 Merc's Avatar
52 Merc
I'm not the Ford-o-matic expert, but I can tell you to be careful what you ask for. The drive gear is the one inside the transmission. The driven gear is the one on the end of the speedo cable. Fyi.
Old Jun 14, 2018 | 06:45 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Pepsford
Hey guys quick question hopefully it's an easy one, trying to order my speedometer DRIVEN gear that connects to my speedometer cable...
The book says to count the number of teeth and my '53 Ford-O-Matic options are 18-19-20-21 teeth. I'm assuming they are talking about the teeth in the transmission.
What in the world?
You count the number of teeth on the DRIVEN gear. There are different transmissions, rear axles/ratios and tire sizes, so there are different tooth count DRIVEN gears.
So, what is its tooth count on the DRIVEN gear, is it nylon or steel? If it's steel, it may have a partial part number on it.
DRIVE gear located on the output shaft. And...I'm not singling you out, I've been typing these two gears in CAPITAL letters in 100's of posts since 11/2006.
Old Jun 14, 2018 | 07:05 PM
Pepsford's Avatar
Pepsford
Gotcha thanks for the clarification...
Old Jun 15, 2018 | 09:54 AM
bjmayberry2's Avatar
bjmayberry2
Veteran: National Guard
You’ll need to know transmission, rear axle ratio and tire diameter. Most of the smaller transmissions are 1 to 1 (except OD transmissions).
This may help: Speedometer Gear Calculator and Charts - TCI® Auto
Aaron Keiser
Sep 30, 2018 10:28 PM
bcamill
Oct 18, 2015 06:54 PM
matt2491
19
Mar 8, 2008 11:54 AM
tatonka04
Nov 15, 2006 08:38 AM
TXDod65
Apr 19, 2006 11:26 AM
