Offset not lining up
Old Jun 13, 2018 | 05:50 PM
BigBlock25O's Avatar
BigBlock25O
Hi all
I bought my trucks (a 250) with the lift and a Dana 60 swap already in it. I have always noticed that the front end was slightly wider then the rear by about 2 inches. My question is, is this a common issue and what is the solution. I already have 2 inch spacers all around and need to keep them on the front for rubbing issues under turning. I I have also heard of guys running dually hubs as large spacers but wanted some more information.
Thank you
Old Jun 13, 2018 | 08:49 PM
Bruce W.'s Avatar
Bruce W.
On my '97 F350 4X4, the front tread width (D60) was about 4" wider than the rear (Sterling 10.25). I used 2" spacers each side to bring the rear wheels out in line with front wheels. No more dog-track look. I don't know about the dually hubs you mention.
Old Jun 13, 2018 | 08:56 PM
Diesel_Brad's Avatar
Diesel_Brad
Originally Posted by BigBlock25O
Hi all
Thank you
Sounds like you have the wrong wheels in the front if you need to run a spacer.
Dually spacers are roughly 3" and that is A LOT of spacer on a 3/4 ton truck
Old Jun 14, 2018 | 01:36 AM
1TonBasecamp's Avatar
1TonBasecamp
But it's also very common for the front solid axle of a truck to be wider than the rear. It's how probably most trucks (at least non-dually trucks) were delivered from the factory.
Especailly true for the Dana 60 solid axles from '78 and '79.
My F350 is bone stock in that department, with the same wheels front and rear, and the front tires stick out of the fenders noticeably more than the rears. Even more than the same truck with a Dana 44 in the front.
It has to do with steering angles and such I believe (Ackerman angle maybe?) and is not really something to worry about.
But if you don't like it, you can certainly run spacers on the rear to take care of the visual aspect. Not sure if you'd even be able to feel the difference in drivability or not. If you've driven your truck daily for years, you could probably feel the difference.
Paul
Old Jun 14, 2018 | 04:40 AM
tjc transport's Avatar
tjc transport
i ain't rite
it is supposed to be that way.
having a wider front than the rear keeps the rear tires out of the front tires track.
Old Jun 14, 2018 | 01:02 PM
Bruce W.'s Avatar
Bruce W.
I assume Ford uses the same width Sterling 10.25 in all F250/350 models - be they 4X4, 4X2, SRW, or dually. Imagine the $ Ford saves by having the one-size-fits-all rear end. Correct me if I'm wrong. I do get the ironic humor of the "...rear tires out of the front tire's track", however.
Old Jun 14, 2018 | 04:27 PM
bad_idea's Avatar
bad_idea
The rear axle is suppose to be narrower than the front axle. My jeep is like that too. Not a Ford specific thing, it's common for handling reasons (please don't ask me specifics, I just know it's suppose to be that way). I suggest you leave it be. Most people won't notice it.
Old Jun 14, 2018 | 04:55 PM
tjc transport
i ain't rite
actually, no. the dually is different width than the SWR pickup trucks. AND, cab chassis trucks are different than SRW and DRW pickups too.
Old Jun 15, 2018 | 04:00 AM
Bruce W.'s Avatar
Bruce W.
Thanks for your info...perhaps I was misinformed. The truth is elusive ofttimes.
Old Jun 15, 2018 | 04:58 AM
Bruce W.'s Avatar
Bruce W.
The "handling" aspect of this has piqued my interest. I'm going to do some diggin' to learn the physics involved.
YendraBuilt
Feb 2, 2024 11:47 AM
good to doo
Dec 7, 2014 11:30 AM
F250FarmBoy
44
Mar 26, 2009 06:27 AM
DuallyBoy
Nov 20, 2002 12:08 PM
