All dana 60 rears the same width?
Old Dec 6, 2014 | 11:14 AM
good to doo's Avatar
good to doo
The reason I,m asking is, I bought a 79350 4x4. And when looking at the truck from the front or rear the front tires stick out farther than the rears. So I did some measuring with all the wheels off, and the front dana 60 diff is 2" wider than the rear. And yes all 4 wheels are the same. So that 2" difference in front translates to 1" on each side of the truck.Is this the way these trucks were sold. thanks for your thoughts.
Old Dec 6, 2014 | 11:56 AM
Eli1644's Avatar
Eli1644
From my understanding, yes the front axle is a couple inches wider than the back. It's still seen on newer 4x4 trucks. If it really bugs you, wheel spacers would be your solution. But there's different opinions on that. Good luck
Old Dec 6, 2014 | 01:19 PM
tabascom16's Avatar
tabascom16
Yes the front is a little wider on my 79 F250 with Dana 60 front. That is just the way they were.
Old Dec 6, 2014 | 07:10 PM
Xauterus's Avatar
Xauterus
They turn better with a smaller rear track.
Old Dec 7, 2014 | 08:11 AM
Fordworth's Avatar
Fordworth
Not necessarily true. Ford widened the 10.5" rear axle housing 3" in 1999 with the introduction of the Superduty pickups. I have one of those axles under the rear of my 75 and rear tires now stick out the same as the front. I believe that half ton models match nowadays too.
Old Dec 7, 2014 | 11:21 AM
good to doo
So that is very very interesting. Do these rear diffs have disc brakes as well, cause that is planned for the future. thanks again people.
Old Dec 7, 2014 | 11:30 AM
Fordworth's Avatar
Fordworth
Yes they do, but it's not a straight forward swap. The spring perches need to be relocated and the wheel bolt pattern is different.
likethefords
Mar 7, 2017 07:14 PM
jodyreed71
Jun 30, 2014 10:45 PM
good to doo
Apr 22, 2014 09:28 AM
Rancho*Ryda
Mar 28, 2006 05:12 PM
FordHerrera1978
Feb 13, 2004 01:04 AM
