Help Me Identify This Paint Code
Old Jun 12, 2018 | 07:31 AM
rudygetz's Avatar
rudygetz
4wd Low
Hello everyone.
Can someone help me identify the paint name and code of this f150?
Old Jun 12, 2018 | 07:50 AM
MarkBowers's Avatar
MarkBowers
Wow. Beautiful truck. I looked it up in my 95 product brochure, and it shows that to be Light Opal Clearcoat Metallic. And the interior trim color would be Ruby Red.
It doesn't give paint codes, but I think Light Opal is M6796.
Old Jun 12, 2018 | 08:41 AM
rudygetz's Avatar
rudygetz
4wd Low
Awesome this site shows Light Opal for 1994 Ford Trucks. It shows the paint code as being M6631 Thanks for your help!
Old Jun 12, 2018 | 09:35 AM
MarkBowers's Avatar
MarkBowers
I notice if you continue in that site, it shows M6631 WM as the paint code for Ford trucks, 1994 and 1995. Then it shows M6796 WO as the paint code for Ford trucks, 1996 and 1997. Didn't know they ever gave different codes to the same paint. Don't know what WM or WO mean, pretty sure my door stickers just have the M code number. (Also see Glasurit uses the Ford numbers-Glasurit is good paint) Anyway, it's nice looking OBS/9th Gen truck.
Old Jun 12, 2018 | 07:28 PM
Diesel_Brad's Avatar
Diesel_Brad
looks just like my 97 Light Opal Metalic paint code WO
Old Jun 12, 2018 | 10:13 PM
eagle275's Avatar
eagle275
I looked it up and I was gonna call it Night Prowler Stealth Grey
Old Jun 12, 2018 | 11:03 PM
McLeod's Avatar
McLeod
My 95 - Light opal metallic - door sticker code WM
Old Jun 12, 2018 | 11:11 PM
McLeod's Avatar
McLeod
It looks like in 97 they offered a WO and a WM, with the WO being slightly darker.
The original post looks to be a darker shade like yours.
That truck also has the pre 95 doors on it.
Old Jun 13, 2018 | 07:19 AM
krooser's Avatar
krooser
Paint codes varied depending on mfg. plant and supplier. Today you may see 10 variations of a given color...
Old Jun 13, 2018 | 12:56 PM
McLeod's Avatar
McLeod
I discovered that when I bought a quart of this WM paint.
Internal documents from the paint supplier showed slightly different formulations within the same year/code and it was up to the buyer to select the correct one for the application.
Makes it difficult to paint repairs seamlessly unless you are good at blending.
Old Jun 13, 2018 | 03:12 PM
rudygetz's Avatar
rudygetz
4wd Low
Hmmm..that sucks. I'm hoping to go with the LIGHTER version of Opal and if it varies that may defeat the purpose.
Old Jun 13, 2018 | 04:58 PM
McLeod's Avatar
McLeod
It was a pretty minor difference between the two products of the same code if that matters.
And that MAY be the specific manufacturer I sourced - Third Dimension -(Sherwin Williams).
Other paint companies may just go with a one size fits all....
Take truck with you and compare paint chips to your existing if you are not doing a complete re-spray.
Is that your truck or just an example of a color you want?
Old Jun 13, 2018 | 05:04 PM
McLeod's Avatar
McLeod
I just had mine repainted with the same code, but PPG paint in bc/cc and the new paint is not exactly the same as the old OEM paint - you can see it in the door jambs.
And the Third Dimension I bought years ago was a single stage urethane and it looks different too, but I think it was because that seemed to have more metallic in it than OEM.
Good luck!
traveller1002000
2009 - 2014 F150
Jun 17, 2017 12:32 PM
ndazley
23
Nov 2, 2014 07:20 AM
BobbyB
Jun 7, 2011 12:06 PM
Knight70F250
Apr 14, 2005 08:58 PM
muscletruck7379
General Automotive Discussion
Sep 8, 2004 02:52 PM
