Engine Ping: Sounds like thick glass
Old Jun 11, 2018 | 09:08 AM
wcwinans's Avatar
wcwinans
Question Engine Ping: Sounds like thick glass
So I was running the engine and heard a ping every once in a while while driving. it sounded like a piece of thick glass would get dinged.
I recorded a video here. Around 5 seconds you can hear it.
Old Jun 11, 2018 | 09:15 AM
Conanski's Avatar
Conanski
Check the base timing setting with a light, should be 10deg BTDC with the spout plug removed to disable computer advance.
Old Jun 11, 2018 | 01:58 PM
wcwinans's Avatar
wcwinans
Before top dead center?
arent you supposed to use cylinder 1 to do that? Cylinder 1 in these vans are damn near impossible to get to.
Old Jun 11, 2018 | 02:38 PM
Conanski's Avatar
Conanski
Yes Before top dead center, cylinder 1 is passenger side front and you just need to clip the timing probe on the plug wire anywhere along it's length.
ghostshark
Jun 12, 2014 04:06 PM
custom1106
Dec 19, 2010 12:50 AM
gt4660
Jul 28, 2010 02:49 PM
BigRedBronc
1978 - 1996 Big Bronco
Mar 6, 2005 07:19 PM
alanvng
Apr 11, 2004 05:39 PM
