Timing 96 5.0
While troubleshooting another problem, I decided to check my base timing. I have not done this before on this Bronco, although I have done it many times before on my previous and other folks Broncs.
I have a MSD 6A, so I disconnected the MSD box and hooked up my stock ignition to get a more true reading. Started the Bronc to make sure everything was working properly. Started up and ran just fine.
Hooked up the timing light to make sure all was well on that end, light working fine but timing mark no where in sight. Shut it down and pulled the spout. Started up and Bronc running like a couple of cylinders were not firing. She started and ran, but definately a serious problem. Re-installed spout, truck runs fine. Pulled spout, same symptoms. It would appear that #1 cylinder is one of the cylinders not firing, as the timing light will not work with the spout pulled and the rig is misfiring.
I have never seen this one before, and cannot figure out why she would stop firing on all cylinders with the spout pulled. Pulling the spout should only disable computer controlled advance, not cause what I am seeing.
Any ideas?
I agree, thats really strange. Your assesment of the SPOUT connector is right to the best of my knowledge. It should only remove the control of spark timing, not the spark itself. Gonna ponder this a bit more but I have nothing logical to add beyond what I have at this point.
Here is an odd thought (and it may not be a viable point because I am not as well versed in the OBD-II as I am the EEC-IV)... does the OBD-II have the capacity to reduce or remove spark to a given cylinder if it detects a misfire in an injector? So, in short can the computer kill the spark to one plug if the injector quits (sparing the dead cylinder the agony of being "dry fired" because no fuel is getting through)? I don't know the answer but if the OBD-II has this capability, it may be the start of an answer.
I am thinking of an experiment to at least determine which cylinders are or are not firing. Here is my thought:
1. Using the inductive timing light check each wire with spout connected to prove or disprove that all eight cylinders are firing.
2. Using the timing light again check each wire with spout disconnected to determine which cylinders are not firing.
Although this test will not really resolve anything, at least it will give me a clearer picture of the scope of the problem.
If there are any FOMO computer gurus out there, I could sure use your help on this one.
Here goes...
I wonder if it is possible that my timing chain has jumped a tooth and the computer is compensating? No idea if OBD II has enough brains to pull this off, but I am grasping at straws here.
My thought is based simply on the fact that cylinders are not firing with the SPOUT pulled, but everything works fine with the spout in.
I figure by now you are either going "hmmm...I wonder" or you just fell out of your chair holding your sides laughing. Either way, at least your thinking about it...
Now that I have fixed this gremlin, we will see if it also solved my 171, 174 code problem (ignition timing fault is a possible cause according to Alldata). I hope so, because I have ruled out just about any other possibility.
Anyway, this one was a head-scratcher, so I thought you would like to know.
