7.5 misfire.
Old Jun 10, 2018 | 04:26 PM
TheOfficialTiny's Avatar
TheOfficialTiny
7.5 misfire.
Hey y'all, I'm new here but I've joined out of necessity at this point. Ok so on my 1994 F350 7.5 I've had a misfire problem for the past year or so. I'll be sitting at a stoplight and the truck will will stutter almost like someone cycled the key quickly. It would normally do this once either stopped or driving and it's been really irritating. The idle would also pickup while sitting at a stoplight and the truck would surge forward. Fast forward to today, I get the 3G alternator conversion done and it charges like it should but this problem is greatly amplified. I had a starting problem and it was narrowed down to a bad hall effect sensor in the distributor, so I replaced the distributor, coil and ignition module. It won't throw a code so any ideas would be appreciated because I'm at a loss.
Old Jun 10, 2018 | 07:04 PM
TheOfficialTiny
Finally found it. The Delphi ignition control module was bad. Stuck the module on my F150 same issues. Ended up buying a motorcraft module and that fixed it.
TheOfficialTiny
Jun 12, 2018 03:04 PM
mdbbrown
13
May 13, 2017 08:03 PM
73FordF100
25
Jun 12, 2011 11:51 AM
FordLuvinJarhead
Electrical Systems/Wiring
Jul 1, 2003 09:45 AM
FrankM
Oct 6, 1999 05:54 PM
