1990 302cu ignition problem
Old Sep 29, 1999 | 06:09 PM
FrankM's Avatar
FrankM
My 1990 F-150 w/a 302 suddenly won't start. Their is no spark from the coil. I've been told to check the electronic ignition module but I'm not sure of its location. Sure would appreciate any help.
Old Sep 29, 1999 | 07:59 PM
Mulletwagon's Avatar
Mulletwagon
A frequent culprit for a no-spark condition (assuming voltage is reaching the coil) is the TFI module (bolted on the side of the distributor) or the PIP sensor (Hall effect device in the distributor). Good place to start. HTH
Old Sep 30, 1999 | 11:36 AM
nissanjon's Avatar
nissanjon
my 87 302's ignition module just gave up about 2-3 weeks ago. a simple remove and replace did the job. it was the original module, afterall.
Old Sep 30, 1999 | 05:33 PM
Pastmaster's Avatar
Pastmaster
>to start. HTH
Hey: Where is the ignition model anyways. I think I know where it is on my '89, but lost as to its whereabouts on my '93...
Thanks!!!!!!!!!
Evan A.K.A. PastMaster
1993 F-150 302/E40d XLT
1989 F-150 302/Aod 4x4 XLT Lariat
Old Oct 2, 1999 | 09:15 AM
deleontow's Avatar
deleontow
It is located on the side of the distributor, it is where the wires conect. It has two small bolts That attach the module to the distributor, you will need a small tool designed for this.
Dave
Old Oct 3, 1999 | 02:49 PM
Pastmaster's Avatar
Pastmaster
I found the TFI module, it is on the inner fendor on the driverside, but I still can't find the ICM. I was looking for it in my Haynes Manual Page 5-11, and it stated that it would be a remote mount. What would that mean?
Thanks!
Old Oct 6, 1999 | 05:54 PM
rick's Avatar
rick
